mole2000
WebService response object in XML - parsing attributes
May 6, 2013 12:10 PM
Tags: #flex-4.6 #soap #web_services
Hi- new to Flex and I'm trying to parse out the attributes of the response object. I can get the entire object and see that its working, but I cant get just a single attribute. It pulls weather info for world cities. For example, I just want the location name and temperature.
Any advice on this? Thanks!
<?xml version="1.0"?>
<!-- fds\rpc\RPCResultFaultMXML.mxml -->
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                xmlns:s="library://ns.adobe.com/flex/spark">
    <mx:Script>
        <![CDATA[
            import mx.rpc.soap.SOAPFault;
            import mx.rpc.events.ResultEvent;
            import mx.rpc.events.FaultEvent;
            import mx.controls.Alert;
            import mx.utils.ObjectUtil;
            public function showErrorDialog(event:FaultEvent):void {
                // Handle operation fault.
                Alert.show(event.fault.faultString, "Error");
            public function defaultFault(event:FaultEvent):void {
                // Handle service fault.
                if (event.fault is SOAPFault) {
                    var fault:SOAPFault=event.fault as SOAPFault;
                    var faultElement:XML=fault.element;
                    // You could use E4X to traverse the raw fault element returned in the SOAP envelope.
            public function log(event:ResultEvent):void {
                // Handle result.
                trace(event.result);
                //trace(ObjectUtil.toString(event.result));
                //var len:int;
                //len = event.result.length;
                //trace(len);
                //trace(event.result);
                //trace(event.result.GetWeatherResponse.Location);
                //var myXML:XML = new XML(event.result);
                //trace(myXML.attribute("Location"));
    </mx:Script>
    <mx:WebService id="WeatherService" wsdl="http://www.webservicex.com/globalweather.asmx?wsdl"
                   fault="defaultFault(event)">
        <mx:operation name="GetWeather"
                      fault="showErrorDialog(event)"
                      result="log(event)"
                      resultFormat="xml">
            <mx:request>
                <CityName>{myCity.text}</CityName>
                <CountryName>{myCountry.text}</CountryName>
            </mx:request>
        </mx:operation>
    </mx:WebService>
    <mx:TextInput id="myCity" text="Madrid"/>
    <mx:TextInput id="myCountry" text="Spain"/>
    <!-- Call the web service operation with a Button click. -->
    <mx:Button width="60" label="Get Weather"
              click="WeatherService.GetWeather.send();"/>
    <!-- Display the Weather -->
    <mx:Label text="Weather:"/>
    <mx:TextArea text="{WeatherService.GetWeather.lastResult}" height="200"/>
</mx:Application>
    May 9, 2013 12:28 PM   in reply to mole2000
    The WSDL says GetWeatherResponse is a string, and it appears to be a string of XML, so set <mx:operation resultFormat="object"> as this will unwrap the SOAP response value and leave a string typed value intact. You can then create a new ActionScript 3.0 E4X-based XML instance from the unwrapped string:
        var myXML:XML = new XML(event.result.toString());
    You can then travese the XML document using E4X syntax, a simple example is included below:
        trace(myXML..Location);
        trace(myXML..Temperature);
