Allbyc
How make a audio -20dbfs
May 6, 2013 2:44 PM
Is the audio VU in Premiere CS6 in DBFS?
The TV station ask me for a -20dbfs audio, how I visualize correctly in the VU?
Best.
Allby
    May 6, 2013 5:03 PM   in reply to Allbyc
    The Master is measured at 0dBFS.  To have it peak at -20 dBFS, adjust the Master in the Mixer to -20.
    Also, take a look at what's coming...
    http://tv.adobe.com/watch/creative-cloud-for-video/adobe-audition-cc-t c-electronic-itu-loudness-radar/
    May 7, 2013 2:58 AM   in reply to Jim Simon
    The -20 dBfs is most probably the reference level. This is the level you would put a 1kHz tone at. However, typically audio peaks to 8dB above reference level, which in your case means audio should not exceed -12dBfs. However you had better check exactly what the TV station expects. They should have a technical spec which will explain what they expect in terms of levels.
    May 7, 2013 3:16 AM   in reply to Allbyc
    Allbyc > do you mean they ask you to include a -20 dBfs reference in your program ?
    May 7, 2013 3:35 AM   in reply to Allbyc
    Peak at -20 dBfs ? odd, that's very low.
    Anyway if you want to get precise control over your mean and peak levels you should do the mix in Audition. As Jim said the next version will get a killer tool for audio metering but it isn't there yet.
    May 7, 2013 3:51 AM   in reply to KGCW
    Allbyc, please re-read what I said in #2 above. You have misunderstood. The following is how the BBC and others do it.
    http://www.bbc.co.uk/guidelines/dq/contents/television.shtml
    This is an extract;
    3.1.1 Stereo line-up tones
    All stereo tracks must use EBU 1kHz tone (left ident). All tones must be sinusoidal, free of distortion and phase coherent between channels.
    Digital Audio Reference level is defined as 18dB below the maximum coding value (-18dBFS) as per EBU recommended practice R68.
    3.1.2 Stereo audio levels and measurement (loudness or volume)
    Stereo programme audio levels are currently measured by Peak Programme Meters (PPM). The Maximum or Peak Programme Level must never exceed 8dBs above the programme’s reference level.
    May 7, 2013 4:48 AM   in reply to Allbyc
    What they're asking you is to include a reference most probably at the beginning of your program.
    Premiere Bars and Tone have a stereo 1 kHz sine wave at -12 dBfs.
    Right click in your project panel and select New Item > Bars and Tone.
    Once it's created right click on it and select Modify > Audio Channels and configure it like this :
    Then right click on the Bars and Tone clip again and select Audio Gain, then lower it by 8 dB :
    You got your reference colorbars with four channels of 1 kHz sine at -20 dBfs.
