Problem with Master Template and exporting
May 7, 2013 5:47 AM
Tags: #pdf #cs5.5 #export #master
ID CS 5.5. Version 7.5.3
Windows 7
Hi Forum,
I am applying a simple Master template to a 28 page document.
If I export to pdf using the pre-defined format for smallest file size or PDF/X-4 the export is correct:
If I export using the pre-defined PDF/X-1a or X3 I get some pages like this (Logo and Page-No. block on both sides):
This only happens on pages 8-9, 16-17, 22-23 out of 28 pages.
I have tried exporting to idml and reopening.
I have removed the master from all pages, checked for spurious elements and then re-assigned the master.
Drunk a lot of coffee!
No pictures go over the gutter.
I need the finished PDF to be in PDF/X-1a.
1.) Why does InDesign hate me?
2.) Can someone please suggest a cure?
Thanks for your time and consideration.
    May 7, 2013 6:00 AM   in reply to NickOnTheNet
    Do you have any hidden layers?
    May 7, 2013 6:32 AM   in reply to NickOnTheNet
    Is that one color bar spanning the spread, or two bars?
    May 7, 2013 7:46 AM   in reply to NickOnTheNet
    No, but try using individual bars instead. I think there's a bug that does this.
