2298993
please help me please please, i will thankful to you all
May 7, 2013 5:36 AM
i have made video through after effects. when i render its size was 603 MB, i cant  upload it  in vimeo, it was h264 , then i render it with wmv now its size was reduced 306MB, but its image quality was very very low, and bad, please guide me how i render my video with high quality and size should be 500 mb
    May 7, 2013 6:43 AM   in reply to 2298993
    You need to provide your exact render settings and screenshots.
    Mylenium
    May 8, 2013 2:29 AM   in reply to 2298993
    Use the Adobe Media encoder instead.
    May 8, 2013 2:55 AM   in reply to 2298993
    You will be hard-pressed to cram a 1.5 hour movie into less than 500MB in any encoder while retaining a reasonable quality. This is slightly insane. Split the movie into separate parts or upgrade your Vimeao account to Pro/ Plus to be able to upload larger files.
    Mylenium
    May 8, 2013 3:15 AM   in reply to 2298993
    you need to understand the difference between rendering and compression. Use AE to render in the best quality you possibly can and THEN use adobe media encoder to compress this rendered file to any format and any size you like.
    This is not only faster (because you only compress and not having actually to render each effect for each frame again) but also more convenient because you have templates for most video sites and formats and also see an estimated filesize.
    May 8, 2013 4:00 AM   in reply to 2298993
    You can render your AEP directly in the Adobe Media Encoder.
    May 8, 2013 4:37 AM   in reply to Rick Gerard
    yes this is possible but not the best/fastest of all workflows
    May 8, 2013 5:14 AM   in reply to 2298993
    It is included with your licensed copy of After Effects.
    May 8, 2013 6:28 AM   in reply to 2298993
    Open up After Effects, click on the help menu and there should be an Activate option below. Let's hope you're not working with a cracked version
