CS Exporting to Epub question
May 7, 2013 1:47 PM
I'm using the articles panel so I can have ID export certain items in order. Works fine but I have a few items that are made up of from more than one layer.
For instance an image of a bell is over a pink circle graphic made to look like large bullets. When I export to epub each of these as expected comes up as a separate item. is thewre a way to merge layers to have more than one item come up on top of each other?
I'm sure there is.
last question, I have thre same problem with some text which is actually the chapter title with a rectangle box underneath. I would think merging these would cause me not using that text in the TOC for a chapter title am I right?
any help around these situations?
thx
RD
    May 7, 2013 1:55 PM   in reply to mentlity
    I would group the objects you want together. Then select the group and rasterize with Object > Object Export Options.
    May 8, 2013 7:21 AM   in reply to mentlity
    Yes, group everything, then rasterize.
    May 8, 2013 10:13 AM   in reply to mentlity
    What Steve said: "Then select the group and rasterize with Object > Object Export Options."
    May 8, 2013 11:23 AM   in reply to mentlity
    Here's an example. Cover made up of three elements—large picture, small picture and type. All grouped together:
    Here are the settings in Object > Object Export Options:
    Here's the result in ADE:
