calcerts
Blurry end product?
May 7, 2013 8:49 PM
Tags: #photoshop #elements #transfer #11 #problems #premier
I shot all imagery in HD and it looked good while editing but when I did the "share" at the end, no mattter which format, they all look slightly out of focus.  Having been a cameraman in the past, I know focus and lack of when I see it and this seems pronounced.  I'm wondering if I'm missing a toggle somewhere??
Thanks,  Kevin
    May 8, 2013 8:39 AM   in reply to calcerts
    Kevin
    When you say that the "HD" looks good while editing are you talking about the rendered Timeline at playback in the Edit Mode Monitor? If so...
    Your export settings need to be looked into.
    Please supply the following information, and I will suggest some settings for you to try to solve and/or identify the core of your issue.
    What version of Premiere Elements are you using, on what computer operating system (including 32 or 64 bit)? Is your computer optimized and drivers up to date?
    Project Preset
    Properties of Source Media (including video/audio compressions, frame size, frame rate, progressive or interlaced, if interlaced Field Order: Lower or Upper Field First, file extension, duration.
    What is your first choice for export of this video to a file saved to the computer hard drive or to disc (DVD or Blu-ray)?
    Let us start here.
    Thanks.
    ATR
    May 10, 2013 6:34 PM   in reply to calcerts
    Kevin,
    Thanks for the follow up. I just need to pin point a few more details and then I will suggest a what next.
    1. For the 720 x 480, could you download the free MediaInfo and get a properties readout for your file. You have posted much of the information, but I would like to confirm display standard 4:3 or widescreen 16:9 as well as Scan Type and Scan Order. Hopefully we will see the requested information in the MediaInfo properties readout.
    http://mediainfo.sourceforge.net/en
    2. This is what I would like you to try as a preliminary test
    Open Premiere Elements 11, go to File Menu/New/Project and in the New Project dialog that opens, set the project preset to either NTSC DV Standard or NTSC DV Widescreen, depending on whether you have standard or widescreen footage. Both will have a frame size of 720 x 480, but widescreen will include a 16:9 flag for video stretching for display after encoding. Before you close out of the New Project dialog, make sure that you have a check mark next to "Force selected Project setting on this project".
    Next use Add Media to bring your file into the program and its Project Assets area. From Project Assets, drag the file to the Timeline (Expert view).
    a. Is there an orange line over the Timeline content? If yes, proceed. If no, press the Render button above the Timeline or go to Timeline Menu/Render Work Area. After rendering is completed, the orange line over the Timeline content will be replaced with a green one. That is the program telling you that you are seeing the best possible preview in the monitor. Once you edit that video, the line will be red. This color indicator system is for letting you know when you are looking at the best possible preview that the program can give. No colored line and green mean, best possible preview displaying; orange, means rendering needed to get possible preview. So, I would ask what is the quality of the rendered Timeline content when viewed in the Edit Mode monitor?
    If you have 720 x 480 widescreen footage and your project is set for NTSC DV Widescreen, your video should fill the space in the monitor...no black borders.
    For your export, let us try Publish+Share/Computer/MPEG with Presets: = HD 720p30. See what that looks like played back in Windows Media Player.
    Keep in mind that you are not starting with high definition video. With those properties that you posted, you have standard definition that could be 4:3 heading for a HD 16:9 export. Right now I am assuming widescreen footage.
    Let us use the above test to get a baseline and then decide what next in your preparation for Facebook and a 1280 x 720 (720p30) there.
    Thanks.
    ATR
