&amp is not encoding correctly in ColdFusion
May 8, 2013 7:04 AM
I am using "&amp" in a coldfusion variable and assigning this to another variable. And I dumped this variable but am not getting results as I expected instead it outputting as below.
<cfset x = "abdul &amp; latheef">
<cfset y = x>
<cfdump var = "#x#">
<cfdump var = "#y#">
Actual Output:
x = abdul &amp latheef
y = abdul &amp latheef
Expected Output:
x = abdul & latheef
y = abdul & latheef
Any idea about this why am getting output as I explained in Actual Output: . Timely help well appreciated.
    May 8, 2013 7:46 AM   in reply to Abdul L Koyappayil
    Why would you expect an ampersand instead of the HTML encoding?  You are dumping the value of the variable, which contains the encoded version.  Just as if you outputted the variable.
    If you output that variable to the browser you will also get the encoded version, but *the browser* will properly decode it to the ampersand. That is the result you *should* be desiring.
    Jason
    May 17, 2013 3:59 AM   in reply to Abdul L Koyappayil
    &amp; is correctly encoded in ColdFusion. The result you're getting is expected.
    Now, some explanations. Browsers do in general render &amp; as &. You should realize that the cfdump tag converts & into &amp;, whereas cfoutput leaves it intact. Hence, if you run this code,
    <cfset x = "abdul & latheef">
    <cfoutput>#x#</cfoutput><br>
    the result sent to the browser will effectively be
    abdul & latheef<br>
    abdul &amp; latheef
    The browser renders this as
    abdul & latheef
    abdul & latheef
    which is the final result you see. However, if your starting point is this code instead
    then the result sent to the browser will effectively be
    abdul &amp; latheef<br>
    abdul &amp;amp; latheef
    abdul & latheef
    abdul &amp; latheef
    This explains why you see abdul &amp; latheef.
