my pdf file is 272 mb how can I make that smaller (100mb)?
Two Ways :
You can sometimes reduce the file size of a PDF simply by using the Save As Other command. Reducing the size of PDFs improves their performance—particularly when they’re being opened on the web—without altering their appearance.
The Reduce File Size command resamples and recompresses images, removes embedded Base-14 fonts, and subset-embeds fonts that were left embedded. It also compresses document structure and cleans up elements such as inval
Two Ways :
The Reduce File Size command resamples and recompresses images, removes embedded Base-14 fonts, and subset-embeds fonts that were left embedded. It also compresses document structure and cleans up elements such as invalid bookmarks. If the file size is already as small as possible, this command has no effect.
For More Details : http://help.adobe.com/en_US/acrobat/using/WSFCDFBF6D-795A-4364-BA93-BB157AAD53ED.w.html
Or
refer the below link : http://help.adobe.com/en_US/acrobat/using/WS58a04a822e3e50102bd615109794195ff-7c88.w.html#WS58a04a82...
Tv Tutorial : http://tv.adobe.com/watch/acrobat-x-tips-tricks/quick-tip-how-to-compress-a-pdf-file/
Reducing PDF file is a frequent question i've come across. Now I have some technique to reduce it.
First, if you're working with Indesign file and trying to export pdf then it will be much easier to reduce pdf file.
1. Working with Indesign to export PDF
a. Goto file and choose Export option or press Ctrl+E and choose Adobe PDF (Print). In the Export Adobe PDF dialogue box goto Compression - Color Images-Bicubic Downsampling-Pixels of your choice-Image quality(Maximum, High, Medium, Low, Minimum) and For Grayscale Images do the same.After all the setup click on export button.
b. Goto to file and click on Print (Ctrl+P) and choose the printer as Adobe PDF
c. If the above two option is not working fine - Create a duplicate master pages of A. Now you've Master Page call A and B. Now delete right side of master page A and delete left side of master page B. Applied master page B on it after that unchecked the facing pages. And goto file and click on Export-Adobe PDF (Interative)-Compression-Image compression-JPEG Quality (Max, High, Medium, Low, Minimum)-Resolution(300 and below)-and click on export button.
d. Goto file and Export to EPS file after that combine all the Eps file in Adobe Acrobat Pro.
N.B.: Adobe PDF (interactive) will help you a lot to export pdf file in a low size and a better quality).
2. Working with Acrobat Pro (there's a few option and technique to reduce Pdf file in Acrobat Pro upto you satisfation but you can these)
a. Goto Redue File size and keep retain existing
b. Goto Advance Optimization (Optimize PDF) and do all the option in Images.
c. Press Ctrl+P (Print) and choose the printer as Adobe Pdf and setup in Page sizing & Handling and print.
3. Working with PDF + Indesign
Goto script and choose place multiple pdf file and uncheck the page facing and export the file to Adobe Interactive or print the file to Adobe PDF.
---- If there's any problem with it in reducing pdf file you can email: philippanmei77@gmail.com
Thanking you hope it will help you alot.
