ComDoc1
PSE 11 Editor fails to restart after exit
May 8, 2013 9:13 PM
Organizer and Editor launch after computer restart. But, after exit the program, only Organizer will re-launch- Editor won't. The PSE Editor PROCESS continues to run in the Task Manager even AFTER I close the Editor. - and ONLY if I END the Process in Task Manager ( or re-start the computer) will the Editor then launch. Did a clean install. Problem continues.
  • 99jon
    Jan 6, 2010
    May 8, 2013 9:41 PM   in reply to ComDoc1
    Try quitting the Editor using Ctrl+Q
    May 8, 2013 10:26 PM   in reply to 99jon
    Try launching with anti-virus off or removing PSE from conflicting list. At times it gets caught in between..
    May 10, 2013 1:57 AM   in reply to ComDoc1
    Try this:
    Quit PSE if already launched
    Switch off your net connection.
    Try using PSE now.
    Also can you enhance the performance from tips here http://blogs.adobe.com/pselements/tips-to-enhance-photoshop-elements-p erformance/. Might be a low memory issue when editing and not qutting properly after some editing. Just trying to explore what might be causing this.
    May 12, 2013 11:03 PM   in reply to ComDoc1
    Can you share your system config info from here Help->System Info
    May 14, 2013 1:12 AM   in reply to ComDoc1
    Have you installed or are using any third party plugin with PSE 11. In that case try removing it and check if it works fine. You can also skip loading of any third party plugin during launch (http://blogs.adobe.com/pselements/skip-loading-of-optional-and-third-p arty-plug-ins-in-photoshop-elements-editor/)
    Are you also using any network printer or scanner or any printer or scanner if locally.
    Garry
    May 14, 2013 10:11 PM   in reply to ComDoc1
    Glad you got it worked finally
