Cold Fuison 10 Installation issues
May 9, 2013 11:08 AM
I am installing Colf Fusion 10 Enterprise Edition on a Windows 2003 Server.
Below is the installation information:
Installation Directories:
   Product: D:\ColdFusion10
Server Information:
   Web Server: Internet Information Server (IIS) (All)
   ODBC Services: installed
   ColdFusion Solr Search Services: installed
   ColdFusion .NET Integration Services: installed
   Microsoft .NET version: v2.0.50727
   .NET Java Port: 6085
   .NET Client Port: 6086
   Documentation: installed
   RDS: disabled
Disk Space Information (for Installation Target):
   Required: 598,249,450 bytes
   Available: 17,875,804,160 bytes
Whe the installation tries to bring up the CF admin:
http://127.0.0.1/CFIDE/administrator/index.cfm
The page displayed is: Internet Explorer cannot display the webpage
I checked the IIS Service Manager and there is no display of 0iisservice showing cfamin running. (When compared to the production running CF 9)
In the Application Pools. Also, there is no cfdmin under Sites in the Application Pools.
I checked the Sevices and ColdFusion 10 Application Server and ColdFusion 10 Jetty Service  show Started.
Does anyone have any ideas?
Mike
    May 10, 2013 12:29 PM   in reply to userCold9
    Hello,
    Thank you for your post. Can you remove the existing connector and recreate the same. If, still the virtual directory for CFIDE and jakarta are not added, please try the following:-
    Open IIS Manager, and select the website. Create the virtual directory CFIDE and jakarta.
    • Virtual Directory name CFIDE location {CF-HOME}\cfusion\wwwroot\CFIDE.
    • Virtual Directory name jakarta location {CF-HOME}\config\wsconfig\{magic-number}.
    • Select the jakarta virtual directory in the Connections panel.
    • Double-click the Handler Mappings icon in Feature View.
    • Click Edit Feature Permission in the Actions panel.
    • Ensure Execute is selected.
    Double-click Handler Mappings, click Add Script Map in the Actions panel. Add handlers for cfm, cfc, cfml, cfr, and cfswf extensions and point all of them to {CF-HOME}\config\wsconfig\{magic-number}\isapi_redirect.dll.
    Double-click ISAPI Filters and click Add in the Actions panel. Give a Filter name (for example, Tomcat) and point it to {CF-HOME}\config\wsconfig\{magic-number}\isapi_redirect.dll.
    Note: Enable the following features at IIS the level.
    • ISAPI Extensions
    • ISAPI Filters
    • CGI
    • ASP .NET
    Hope this helps.
    Regards,
    Anit Kumar
