gringer
Compound paths won't work properly
May 14, 2013 3:28 AM
Tags: #problem #compound_path
Hi everyone,
I am relatively new to Illustrator.  I am using CS6.
I am trying to punch holes in a circle using compound paths, as you can see here :
http://i.imgur.com/9v22Bcl.png
The tadpole shape and the human shape are the holes I need created in the large circle behind them.  Both the tadpole and the human are at the front and all objects are on the same layer.  When I select everything and choose CRTL+8, only the tadpole gets cut into the circle.  the other shape just stays white.
Can anyone shed some light on what I am doing wrong?
Thanks!
    May 14, 2013 3:38 AM   in reply to gringer
    gringer,
    You may try Pathfinder>Minus Front (Subtract from shape area in some older versions, maybe requiring your pressing Alt/Option to get a (simple) compound path).
    What happens if you select the human shape and change its fill colour?
    May 14, 2013 4:08 AM   in reply to gringer
    You are welcome, gringer.
