maria j miller
indesign cs6, smart guides on, transform not proportional
May 14, 2013 12:25 PM
Tags: #scaling #transform #scale #free_transform #smart_guides #direct_select #indesign_cs6 #scaling_problem
i use my smart guides a lot. i have found that when i go to transform an image using the direct select tool, and the cmd+shift function, the percentage of the scale is not consistant on teh x and y axis (they should be the same). i do have the "constrain proportions" active. i have tested without them being active. it seems, so far, the only time i can recreate the issue is when the smart guides are active.
-osx 10.8.3
-indesign cs6 (cloud subscription)
-smart guides on
-transform window open
-constrain proportions active
-direct select tool
-select image within a frame with direct select tool (white arrow tool)
-use shift+cmd and drag and scale, repeat (small and large areas)
-repeat a few times and watch the horizontal and vertical percentages in the transform window. percentages will not be consistent after a few tries
does anyone else have this issue?
can anyone else recreate this issue?
does anyone have any suggestions on a fix (other than turning off the smart guides)?
thanks in advance
-maria
