fsoender
Help with IF statement
May 14, 2013 1:10 PM
   public var x:Object;
   public var value:String;
   value = G10;
             if(value)
            x = value;
           if (x<G10)
           Code here...
Why cant I write it like this "if (x<G10)"?
Im trying to read a value from a microcontroller, that have the letter "G" infront of a number. The code works if I use only numbers like this: if (x<10).
Compiler wont accept it, comes with this ERROR:
Multiple markers at this line:
-1120: Access of undefined property G10.
-1 changed line
    May 14, 2013 9:04 PM   in reply to fsoender
    There are a few things wrong.
    First,
    value = G10;
    needs to be in quotes if G10 is really a string
    value = "G10";
    Otherwise the compiler will think it an undeclared variable.
    Next, this is a boolean true / false
    if(value)
    should be a string check
    if(value != null)
    Next,
    x = value;
    That is a value of an Object to a String.
    Could be
    x.value = value;
    And last,
    if ( x < G10)
    this is incorrect because the less than sign wont work
    with strings unless the are a numeric value and using parseFloat or parsInt to compare them
    This would be in the ball park.
    if ( x.value != "G10")
    or if both values were numeric you could use
    if ( parseFloat(x.value) < 10)
    HTH
