Mental Stiv
Need help with Adobe Flash Professional! Somewhat urgent!
May 14, 2013 6:45 PM
Tags: #adobe #flash #frames #professional #cs6 #symbols
In Adobe Flash Professional, How Can I Split The Frames Of An Animated Symbol That Are Placed On The Seed Timeline Without The Symbol Restarting Its Entire Animation After Each Split? I have looked up many online tutorials and none run into this problem.
    May 14, 2013 7:21 PM   in reply to Mental Stiv
    It is not clear to me what your use of the terms "Split" and "Seed Timeline" are refering to.  If you do not want something to loop that is animating based on timeline frames you need to implement a stop() command.
    May 15, 2013 6:55 AM   in reply to Mental Stiv
    My original response stands.  If you want to stop a timeline animation you need to implement a stop() command.
    If you need the animation to start/restart at a specific point then you use a gotoAndPlay() or play() command depending on where that starting point is relative to where you currently are on the timeline.
