Cannot debug - all breakpoints show "Breakpoint not set; No executable code at line ###..."
May 14, 2013 10:06 PM
Tags: #flash #debugger #breakpoints #flash_debugging #debugger_broken
Flash Professional CS6 with all updates. Targeting Air 3.6.0.6090 for Android (but it has been like this for the last few versions),
No matter what I try, I cannot get debugging to work (local or remote) on my Android Air project. When I set a breakpoint and run the code it launches into the debugger, but shows errors like:
Breakpoint not set; No executable code at line 508 of nefertiti_slots.as
Breakpoint not set; No executable code at line 3132 of nefertiti_slots.as
I can assure you that there is indeed executable code at those line numbers and all the others I have tried.
When the debug launcher starts up, the screen shows the stop(); command from the first frame of one of the MCs - and there is a list of scenes and symbols, but it acts like the .as file with all the code in it does not exist even though the build is happily running.
I have been working around this using primitive old trace and print to the screen stuff (like it was 1984) but I need real debugging now and I am stymied.
And please, I know a bunch of you will say to switch to Flash Builder -- but that is not a solution to whay the several hundred dollar program I am using is not working.
    May 20, 2013 1:59 AM   in reply to scober99
    same here
    producitivty killer!
