FraserWalker
CS6 hangs during infuriatingly simple tasks
May 15, 2013 8:28 AM
Tags: #h.264 #hangs #hangup #hang_randomly #hang_up #hang.
For the fifth time today, Premiere has hung on me. Fifth time today, and probably the ninth time in this project. I'm working solely on H.264 Canon 600D .movs, no fancy effects, no third party plug-ins, just a straight forward edit with some standard transitions.
It's hung on me when adjusting the opacity levels with the pen tool. It's hung during an auto-save and a manual save. It hung when I used the 'paste attributes' option. It hung when I scrubbed through an unrendered bit of footage. Once, it even hung while I was reading an article online and Premiere was just sitting idle in the dock!
I have completed several projects using CS6 for corporate clients, charities and even the BBC. Neither myself or my clients have had any complaints until now. When it hangs, I have to force quit. I'm told that Premiere has quit unexpectedly, and would I like to report it to Apple (I'm using a Mac Pro desktop running OS X 10.6.8.) The following is the code that is being sent to Apple each time I get a hang. It means nothing to me, but maybe someone smarter will find something...
Date/Time:   2013-05-15 15:46:28 +0100
OS Version:  10.6.8 (Build 10K549)
Architecture:x86_64
Report Version:  7
Command:     Premiere Pro
Path:        /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/MacOS/Adobe Premiere Pro CS6
Version:     6.0.0 (6.0.0)
Parent:      launchd [102]
PID:         644
Event:       hang
Duration:    5.37s (sampling started after 2 seconds)
Steps:       13 (100ms sampling interval)
Pageins:     0
Pageouts:    0
Process:     Adobe Premiere Pro CS6 [644]
UID:         502
  Thread 586b   DispatchQueue 1
  User stack:
13 start + 52 (in Adobe Premiere Pro CS6) [0x10000361c]
  13 main + 647 (in Adobe Premiere Pro CS6) [0x1000038b7]
    13 Run + 247 (in Startup) [0x10c8911d7]
      13 AppMain + 380 (in Frontend) [0x10c72124c]
        13 FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 5681 (in Frontend) [0x10c6ca4df]
          13 FE::MacApplication::RunSelf() + 44 (in Frontend) [0x10c71fcd4]
            13 -[NSApplication run] + 395 (in AppKit) [0x7fff8656968f]
              13 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 155 (in AppKit) [0x7fff865a3801]
                13 _DPSNextEvent + 708 (in AppKit) [0x7fff865a3eb2]
                  13 BlockUntilNextEventMatchingListInMode + 59 (in HIToolbox) [0x7fff871314ac]
                    13 ReceiveNextEventCommon + 310 (in HIToolbox) [0x7fff871315f3]
                      13 RunCurrentEventLoopInMode + 333 (in HIToolbox) [0x7fff871317ee]
                        13 CFRunLoopRunSpecific + 575 (in CoreFoundation) [0x7fff830aed8f]
                          13 __CFRunLoopRun + 873 (in CoreFoundation) [0x7fff830af5c9]
                            13 __CFRunLoopDoSources0 + 1361 (in CoreFoundation) [0x7fff830b13d1]
                              13 __NSThreadPerformPerform + 219 (in Foundation) [0x7fff82e0845f]
                                13 -[NSApplication _realDoModalLoop:peek:] + 442 (in AppKit) [0x7fff867dedc3]
                                              13 __CFRunLoopRun + 6488 (in CoreFoundation) [0x7fff830b0bb8]
                                                13 __NSFireTimer + 114 (in Foundation) [0x7fff82e46bc5]
                                                  13 -[PremiereCocoaMacApplication idle:] + 108 (in Frontend) [0x10c71e84c]
                                                    13 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void> , bool*) + 125 (in dvacore) [0x10018de3d]
                                                      13 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHa ndler<void>(boost::function0<void>, bool*) + 112 (in dvacore) [0x10018b900]
                                                        13 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHand ler(boost::function0<int>) + 57 (in Frontend) [0x10c6e4af5]
                                                          13 int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0 <void>*, void*) + 28 (in dvacore) [0x10018ba0e]
                                                            13 HandleIdle(NSTimer*) + 92 (in Frontend) [0x10c71fbdc]
                                                              13 FE::DoSuspendResume() + 355 (in Frontend) [0x10c71d743]
        13 ASL::StationUtils::BroadcastMessage(ASL::ImmutableString const&, ASL::Message const&) + 66 (in ASLMessaging) [0x1006fdf72]
        13 ASL::Broadcaster::BroadcastMessage(ASL::Message const&) + 1565 (in ASLMessaging) [0x1006f0841]
        13 ASL::Broadcaster::BroadcastMessageInner(ASL::Broadcaster::ListenerRec ord const&, ASL::Message const&) + 75 (in ASLMessaging) [0x1006ef22b]
        13 ML::VideoPlayerProxy::ListenToMessage(ASL::Message const&) + 457 (in PlayerHost) [0x10499c3d7]
        13 ML::VideoPlayerProxy::OnApplicationResumed() + 168 (in PlayerHost) [0x10498e936]
        13 ML::VideoPlayerProxy::ActivateDevice() + 39 (in PlayerHost) [0x104996fa5]
        13 ML::AsioHostInstanceWrapper::AsioHostInstanceWrapper() + 271 (in PlayerHost) [0x10496cae1]
        13 ML::CoreAudioHost::AddDependancy() + 28 (in AudioSupport) [0x103069392]
        13 semaphore_wait_signal_trap + 10 (in libSystem.B.dylib) [0x7fff878fedc2]
  Kernel stack:
13 semaphore_wait_continue + 0 [0x22a88f]
Anyone??
