avtutorials
CS6: New feature doesn't work: Publish direct to iOS device
May 15, 2013 11:28 AM
Tags: #ios #install #cs6 #device
Just upgraded to Flash CS6 v12.0.2.  It has a new feature, in File > AIR 3.2 For iOS Settings > Deployment tab > "Install Application On The Connected iOS Device."
This feature is disabled.  Does anyone know how to get it enabled?
I do have iTunes installed, per http://helpx.adobe.com/flash/using/packaging-applications-air-ios.html #id_91536 .
  • kglad
    Jul 21, 2002
    May 15, 2013 12:34 PM   in reply to avtutorials
    does your iOS device show up when you use a file browser or in your system tray?
  • kglad
    Jul 21, 2002
    May 15, 2013 1:16 PM   in reply to avtutorials
    that's the problem.
    start here to troubleshoot: http://www.apple.com/support/ipad/assistant/itunes/
  • kglad
    Jul 21, 2002
    Jun 6, 2013 8:16 AM   in reply to avtutorials
    i've not seen this problem before so i suspect the issue is an os problem or usb port problem.  i would be especially suspicous of an usb port issue if the problem is intermittant.
    have your tried a different usb port?
    once your iOS device is recognized by win explorer AND you leave it connected, does win explorer ever fail to continue recognizing your iOS device is connected?
  • kglad
    Jul 21, 2002
    Jun 6, 2013 9:58 AM   in reply to avtutorials
    do other devices that you connect to your front usb ports have intermittant problems?
