americanprinting1
How do I enter sequential numbers, three per page?
May 15, 2013 11:15 AM
I'm making auction bid numbers which are three to a page, and my document is 100 pages long.  I need sequential numbers from 001 to 300.  How do I do that?!  The only sequential number entry in the Index talks about page numbering, which won't work for me because I need three numbers per page.  I tried to make a new variable data entry, but I can only ever get it to say 001.  I'm new to InDesign, but I really don't want to make 300 text boxes and then go in one-by-one and change the numbers.  There must be some way to do this...
    May 15, 2013 11:20 AM   in reply to americanprinting1
    Search Google for terms like "InDesign numbered tickets" without quotes.
    HTH
    Regards,
    Peter
    _______________________
    Peter Gold
    KnowHow ProServices
    May 15, 2013 11:41 AM   in reply to peter at knowhowpro
    Peter G.'s suggestion will probably locate any number of posts about this on this forum -- I know I've given some fairly extensive answers here myself.
    Basically, you have two choices, place a text file that is the number list, or use Data Merge, which will also require the number list. For data merge you can use one number per record and do a multiple records per page merge, which requires a template with only one instance of your placeholder on the page, or do three numbers per record and merge one record per page into a three-up template.
    Frankly, putting three linked frames on the master and placing the number list, using a paragraph style set to start in next frame, is probably easier in this case.
    May 15, 2013 2:08 PM   in reply to americanprinting1
    Are you using a multiple records data merge? We've seen some similar reports, and I think it's probably a bug, but check the margin settings in the merge options, and don't preview before merging.
