Jay.dub
Does it really take 22 hours for AME to transcode 1 hour of ProRes apcn to the YouTube preset?
May 15, 2013 11:18 AM
My question actually is, "Will it always take this long??
If you haven't already checked out my system information, I am at the tail end of of a 6 year old HP 8400.  I have (finally) received the OK to acquire a new system.  While I know that this new system (http://www.pugetsystems.com/saveconfig.php?id=111597) will vastly improve "timeline" speed and After Effects previewing & rendering and should export most CODECs much faster, I'm concerned about the straight transcoding work that I do in AME.  Specifically from ProRes to anything else.
The company for whom I work stages and produces lots of live corporate events.  I create content for the event and then handle whatever the client wants done with the recorded footage afterwards.  Sometimes it's the full boat and sometimes it's just for them to share internally and post on their website.  Either way, typically the first thing that they want is to just see the footage.  So, regardless of what will become of the footage later, I run it through AME and turn it into H.264 using the YouTube friendly preset.
Currently, on my aging machine, AME is using only ~30% of my 8 cores.  Only 7-8 GB of my 20GB of ram and obviously 0% of my GTX285.  So am I to assume that due to CODEC limitations, AME will still take this long to transcode on a machine with twice the cores (including higher clock speeds)  and 3 times the ram?  Will it simply use even less of the system and still take 22 hours??  Will I at least see a reduction in time from the move from DDR-2 to DDR-3 and the other lower latency benifits of current hardware?
I was going to include the "MediaInfo" for the source and final files along with the AME log and some other info but since I've already made this a wall of text, I hold off until someone needs it to answer my question.
Thanks in advance.
Jason
BTW - I've been using Adobe products since the mid 90's (Premiere 4.0, After Effects "Melmet") and I've been lurking here and scraping info from all of you from at least 2 forums ago This is my first post in the "new" forum.
    May 16, 2013 10:18 AM   in reply to Jay.dub
    Hi Jason,
    How can I put things in perspective for you? It sounds like you have no idea what to expect, which is understandable when using really old hardware. And what version of Premiere are you running?
    Computer technology has just made leaps and bounds the last few years, nothing short of amazing! Starting with CS5, Premiere now uses the GPU (display card) to provide hardware acceleration of editing and effects, using the Mercury Playback Engine. The MPE can run on CPU only, but it makes a world of difference when using GPU hardware as well. Of course the software and OS are 64-bit now, which really helps, especially with the large amounts of RAM allowed.
    Years ago, it was pretty much manadatory to get a dual-processor machine for editing. Today's Core i7 quad-core machines basically have 4 processors on one chip, so it is like having multiple processors. Then there is "multithreading", so 4 cores look like 8 cores to the software.
    So basically, any recent Core i7 machine will do a great job of editing and exporting HD footage from Premiere CS6. Many effects, titles, layering and scaling of video can all be done without a red bar! I stacked 15 or 20 layers of 1080i AVCHD once, making multiple PIPs all over the screen, and it still played smoothly without rendering a frame.
    If working primarily with Premiere and Encore, then a 4-core or 6-core i7 machine will make most editors very happy. If After Effects is a big part of your workflow, and/or 3D animation, that is where a dual-XEON machine can make a difference. Really though, working in Premiere, you'd see little difference. Realtime is realtime, an $11k machine doesn't make that any faster.
    On a nice i7 machine costing $3-5k, you should expect H.264 exports around realtime or better. With DV footage, going to MPEG-2 DVD format, a two-hour timeline can be exported in unnder 10 minutes. Seriously. The .wav audio from a two hour timeline? Seconds to export.
    Puget is a respected company with nice gear and if you feel the need for "the best of the best" and have the budget to back it up, that $11k system will certainly rock. We're also an Adobe-authorized system builder and will be happy to consult and provide pricing for comparison as well.
    Here's a link to Dave Helmly discussing new workstation options for CS6 - http://blog.sharbor.com/blog/2012/12/adobes-dave-helmly-discusses-thun derbolt-for-pc-and-tsunami-riptide/
    Thank you for your consideration
    Jeff Pulera
    Safe Harbor Computers
    sharbor.com
    May 16, 2013 11:12 AM   in reply to Jay.dub
    Hi Jason,
    As I wrote earlier, expect exports to be around realtime speed. If I can get access to our demo machine this afternoon for a bit, I will try a sample render from ProRes to YouTube H.264 and get you some actual numbers.
    What I gather from your post is that because the current (old) machine takes 22 hours, and is only using 30% of its potential, that a new machine will still take 20 hours. Not so. Not even close
    Jeff
    May 16, 2013 11:40 AM   in reply to Jay.dub
    I guess I did misunderstand, I was talking about exporting direct from Premiere via AME, I never have much call to use AME by itself for batches or anything. But no, it is not going to take hours and hours either way. Will try and test today and respond.
    Jeff
    May 16, 2013 11:47 AM   in reply to Jay.dub
    Jason,
    Jeff has already given you some perspective on what you can expect from a modern machine.
    Let me add some further information:
    • A three hour single track DV timeline exported to a DV .AVI can be as fast as 22 seconds, although it normally takes around 175 to 275 seconds, depending on the disk setup.
    • A 159 second single track AVCHD timeline, loaded with effects and exported to MPEG2-DVD with MRQ turned on, takes 23 seconds on a really fast system, and normally around 50 to 70 seconds, still better than 2 - 3 x real time.
    Finally, keep in mind that the Prores codec may not be very good at threading. I don't know this for sure, but everything related to Apple, whether it is the 32 bit QuiRcktime or Prores can show weird behaviour and inferior threading.
    For PC users there is no benefit to transcoding to Prores instead of using the native format.
    May 16, 2013 1:57 PM   in reply to Jay.dub
    Hi Jason,
    My rule of thumb is, if I choose a PRESET, and there are boxes that are UNCHECKED, I probably do NOT need to check them - Adobe has figured out the best settings for most users already, and they are unchecked for a reason ;-)
    So anyway, I did already unbox a brand-new Ninja 2 just to prove a point before I saw your admission of guilt. I recorded exactly 60 seconds of ProRes 422, just as the KiPro would, and copied that clip into my editing PC with CS6. Dropped the 1080i ProRes 422 clip into Premiere CS6, and did File > Export > Media and chose the H.264 YouTube 1080p 29.97 preset, and began the export.
    The :60 clip took exactly :75 to complete
    I then fired up Adobe Media Encoder as a stand-alone, imported ProRes clip, and exported using same  YouTube preset, and it again took exactly :75 to export. As I said from my first post, "should be close to real time". The test system is a lowly Core i7-3770 at 3.4Ghz.
    Something else I was alluding to earlier, is that an $11k system will not necessarily be a LOT faster for certain things. One might assume that the dual-XEON system would do the same encode in half the time or less, but in reality, it might shave only 5 or 8 seconds off the encode. Don't ask me why, but that is reality. Now if you are rendering a complex scene in AE, then the big machine will very likely be quite noticeably faster. For instance, using Red Giant DeNoiser plugin, I found that a dual-XEON could render about 3 times faster than an i7 quad-core.
    In any event, a 6-year-old system is not your friend when trying to get something accomplished in the edit suite.
    Jeff Pulera
    Safe Harbor
    May 16, 2013 2:48 PM   in reply to Jay.dub
    For heavy comp work and animation/3D, then a bigger workstation can be very worthwhile. If someone is primarily working in Premiere, then a 4 or 6-core is more than adequate, as Premiere can only use so much oomph behind it.
    Jeff
    May 18, 2013 2:11 AM   in reply to SAFEHARBOR11
    this discussion is missing some important things... a fast and poweful workstation can't help with software bottlenecks in PP and Quicktime...
    --> I run a current CS6 setup on MAC and PC with MPE enabled and Quadro board on MAC - GTX on Win7...
    1. Realtime H.264 encoding?? Would like to read more on this - maybe for the Youtube preset but if you do a propper twopass encoding for 1080p24 Bluray and render from DPX files it's hard to manage...)
    If I encode a 90min feature with AME to M4V Bluray from 8Bit Quicktime it takes about 4.5h on a quad core i7 3.6GHz and about 3h on a dual quad core Xeon MAC 2.4GHz)
    If I encode from DXP render times doubles - Raid is reading just 80MB/s - quad core i7 3.6GHz is just at 75% load - and 90min encoding typically takes about 8h...
    2. If I activate Maximum Depth and Max Render Quality and export to DPX - Raid hasn't load - CPU hasn't load - GPU hasn't load - sytem is idle - but the export takes forever...
    3. If I activate Maxiumum Depth on export only half the CPU cores are used for rendring intense tasks like JPEG2000 encoding - If I export with 8Bit all cores are used imediately. (tested with single socket quad Core i7 3.6GHz and dual socket quad core XEON 2.4GHz)
    so - fast Hardware alone doesn't results in fast render times...
    1. Even on the most recent 8 or 12 core systems you can be happy to get realtime but not much faster (has anybody testet GPU accelerated Bluray compliant HQ encoding from AME??)
    2. If DPX files are part of the workflow things get slow. (fast Raid or SSD helps but not much)
    3. If you activate Maxiumum Deph things will take 4x to 10x as long as with 8Bit - at the same time half of your CPU cores are set to idle - doing nothing anymore
    4. Using 32bit Quicktime + badly multitheraded codecs via IP link seems to slow down PP - If you read and write MOV files rendering takes longer than on native PP formats. (But in real live you get Prores HQ as source files and have to deliver Prores or DNXHD MOV back... so it doen't helps that PP can export MPEG II blazing fast
    so what speed PP up and whats the bottlenecks?
    1. GPU for MPE - mandatory don't try to live without
    2. fast SSD for temp files (media cache) - mandatory don't try to live without
    3. fast RAID and SSD's for footage - esp. on I/O intensive tasks like DPX file lists SSD's are helpful - if the data becomes too big a fast HDD Raid can help (If your Raid can manage 600MB/s be happy if Premeier uses 150MB/s
    4. Fast CPU or dual socket system: currently I only get my quad core i7 3.6GHz with H.264 encoding to 100% load - if I work with DPX files I can't even saturate one CPU with load... before you think of a dual socket system by some PCI-Express SSD-Cards first ;-)
    what will slow down your renderings massively?
    1. Usage of DPX files (regardless of the speed of your Raid)
    2. Usage of Maximum Depth on export
    3. Usage of Quicktime
    Any best practice suggestions?
