Controlling the sound volume of my swf
May 15, 2013 2:47 PM
I am trying to reduce the sound volume of my swf in general. I implemented the code below, but I get this error message: Line 30 1151: A conflict exists with definition in namespace internal.
Thanks for your help
Charine
Here is my code:
package
   import flash.display.MovieClip;
    import flash.utils.Timer;
    import flash.events.TimerEvent;
    import flash.events.MouseEvent;
    import flash.media.Sound;
   import flash.events.Event;
    import flash.media.SoundChannel;
    import flash.media.SoundMixer;
    import flash.media.SoundTransform;
    public class BugGoopFSGame extends MovieClip
       public var mybackground:BackGround;
//        public var LetterArray:LetterArray = new LetterArray(stage);
        public var lettera:A;
        public var cinders:Cinders;
        public var gameTimer:Timer;
        public var spidy:Spidy;
        public var myplaybtn:Play;
        public var timerback:TimerBack;
        public var timermiddle:TimerMiddle;
        public var timerfront:TimerFront;
        public var settings_btn:Settings_btn;
        public var sound1:Sound1;
        public var channel:SoundChannel = (new Sound1()).play(0, int.MAX_VALUE);
        public var channel:SoundTransform = (new Sound1()).volume(0.5,1.0); //This is where the problem is - Line 30 1151: A conflict exists with definition in namespace internal.
        public function BugGoopFSGame()
            sound1 =  new Sound1();
        //rest is not relevant to this
    May 15, 2013 3:57 PM   in reply to Charine -FB buggoop
    You declared two different variables with the same name "channel". Change the name of one of them.
    May 15, 2013 6:11 PM   in reply to Charine -FB buggoop
    This is probably what you should be doing. Define the sound channel and the sound transform objects. Then tell the sound to play through the sound channel, then set the volume for the sound channel through the sound transform.
    public var channel1:SoundChannel;
    public var channel2:SoundTransform = channel1.soundTransform;
    Sound1.play(0, int.MAX_VALUE);
    channel2.volume = .5;
    channel1.soundTransform = channel2;
    See how that works.
    May 17, 2013 12:13 PM   in reply to Charine -FB buggoop
    Can I see the whole Class? You've either left out something or put something in the wrong place.
    May 18, 2013 2:09 PM   in reply to Charine -FB buggoop
    Try this version that I put together. I attached the sound playing to the onClick function at the bottom. This may not be the correct place, you can move the code to any function that you like. The sound will not play from the variable declaration section of the class, it really needs to be in a function.
    package  {
                import flash.display.*;
        import flash.events.*;
        import flash.text.*;
        import flash.net.URLRequest;
            public var letterArray:LetterArray = new LetterArray(stage);
            public var sound1:Sound;
            public var channel1:SoundChannel = new SoundChannel();
                                  // this assumes that you have a sound file in a movie Library
                                  // with a class name of "Sound1"
                sound1 =  new DeltaFog();
                lettera = new A ();
                addChild(lettera);
                                  mybackground = new BackGround ();
                addChild(mybackground);
                cinders = new Cinders();
                addChild(cinders);
                spidy = new Spidy();
                addChild(spidy);
                myplaybtn = new Play();
                addChild(myplaybtn);
                timerback = new TimerBack();
                addChild(timerback);
                timermiddle = new TimerMiddle();
                addChild(timermiddle);
                timerfront = new TimerFront();
                addChild(timerfront);
                settings_btn = new Settings_btn();
                addChild(settings_btn);
                gameTimer = new Timer(31,5120);
                //Add event listener for start button
                myplaybtn.addEventListener(MouseEvent.CLICK, startTimer);
                //Add event listener for timer;
                gameTimer.addEventListener(TimerEvent.TIMER, tickTock);
                gameTimer.addEventListener(TimerEvent.TIMER_COMPLETE, timerFinished);
                gameTimer.addEventListener(TimerEvent.TIMER, fadeIn);
                gameTimer.addEventListener(TimerEvent.TIMER, moveA);
                gameTimer.addEventListener(TimerEvent.TIMER, scaleLifeBar);
                //Add event listener for when lettera is clicked
                lettera.addEventListener(MouseEvent.MOUSE_DOWN, onClick);
            //Start timer function
            public function startTimer(timerEvent:MouseEvent):void
                gameTimer.start();
                trace("Timer started");
                myplaybtn.visible = false;
            public function tickTock(timerEvent:TimerEvent):void
                trace("Tick");
            public function timerFinished(timerEvent:TimerEvent):void
                trace("Timer is finished");
            public function scaleLifeBar(timerEvent:TimerEvent):void
                timermiddle.scaleLifeBar();
            public function fadeIn(timerEvent:TimerEvent):void
                lettera.fadeIn();
            public function moveA(timerEvent:TimerEvent):void
                lettera.moveA();
            public function onClick(event:MouseEvent):void
                trace("The letter a was clicked");
                                  // this line tells the sound to play, it can also
                                  // be "sound1.play(0,int.MAX_VALUE);" if you don't need
                                  // the volume
                                  channel1 = sound1.play(0, int.MAX_VALUE);
                                  // set a value for the volume to be used
                                  // connect the volume to the sound channel
