Why does my adobe reader XI can't print for windows 7
May 15, 2013 11:56 PM
my operat system is windows 7 professional 32bits
i can print other document example word excel outlook...
but if i use adobe reader XI to print PDF document ..no any response from my print
i'm sure i didn't choice print file to document
anyone else has any same question?
i'm try to downgrade to adobe reader X . it's working can print document.  but it's still can't print in a few days later
i uninstall the software and reinstall the software and i delete all adobe document date file
still can't print the document . how should i fix it this problem. thanks all ~~~
    May 27, 2013 9:43 PM   in reply to ivanwin
    Could you please explain clearly what happens when you try to print a PDF doc using Adobe Reader?
    May 28, 2013 11:07 PM   in reply to ivanwin
    Could you please describe as to what happens after you click the print button on Adobe Reader?
    Does the job go to the printer queue or not? you may check this from the printer queue on the system.
    Does it show the printing progress dialog example "dialog showing printing page 1 of 2" ?
    May 28, 2013 11:18 PM   in reply to ivanwin
    Kindly upload the screenshot.
    May 28, 2013 11:46 PM   in reply to ivanwin
    Could you please try to repair Adobe Reader?
    Go to Help->Repair Adobe Reader installation
    I hope you are using Adobe Reader version 11.0.3. You may check the same from Help->About Adobe Reader.
    Jun 10, 2013 12:35 AM   in reply to ivanwin
    Could you please try disabling the "enable protected mode at start up" option from Edit-->Preferences-> Click on "Security Enhanced" (left side pane) ?
    Do not forget to re-start reader after you do this. Let me know if that resolves the problem.
    Jun 18, 2013 12:32 AM   in reply to ivanwin
    Could you please re-enable the setting again and re-launch the Adobe Reader to verify issue still occurs?
    Oct 2, 2013 12:14 AM   in reply to Atul Agarwal
    Thank you. Your Answer helped me too:
    I have Windows 7 Pro SP2 32bit
    I currently have Adobe Reader X 10.1.4 However, I downgraded from the current most recent version of Adobe Reader XI 11.0.04 when I discovered the issue.
    Do you know if this issue will be fixed? What are the ramifications of turning off Protected Mode?
    Thanks Again
    Dec 2, 2013 1:37 PM   in reply to vinnyb
    I follow your steps but I still can't print.
    My issue is, I sent the print and everything looks fine until this window showed up
      And just that, nothing else happened.
    What should I do?
