Adobe Media Server failing to record video if switched from play to record midstream
May 21, 2013 5:01 PM
Tags: #bug #netstream.publish #stream #record #flash_media_server #media_server
The Adobe Media Server is failing to record video if switched from play to record midstream. It is an intermittent issue that happens randomly one out of every 30 attempts.
Flash Runtime: Flash Player ActiveX 11.7.700.169 or Flash Player ActiveX 11.4.402.287
Media Server: AMS5.0.1, also FMS4.5.5
(The problem happens on both FMS4.5.5 and AMS5.0.1)
The ActionScript is as follows:
netstreamRoger.publish("719_Client","play");
Then 1 second later:
netstreamRoger.publish("719_Client","record");
netstreamRoger is streaming out the video and audio data correctly, because there is another computer playing the stream 719_Client live. So the media server is forwarding the stream correctly when live. The bug is when you attempt to playback 719_Client.flv the file does not contain any video data. The file size is not zero, and the file is not corrupted, but the file size is smaller than it would be if it had saved the video in it.
How do I submit this bug to the Media Server team, and how can I workaround this issue?
Below is the log from the Media Server 5.0.1
publishstream2013-05-1516:14:20Mountain Daylight Time719_Client192.168.2.2311284010_defaultRoot__defaultVHost_uGenius_definst_0200192.168.2.219rtmp-rtmp://ugfms:1935/uGeniusrtmp://ugfms:1935/uGenius--WIN 11,7,700,169470211123484408254331893486normal719_Client--rtmp://ugfms:1935/uGenius/719_Clientrtmp://ugfms:1935/uGenius/719_Client--00--00---------------1-1.000000-
connect-pendingsession2013-05-1516:14:20Mountain Daylight Time192.168.0.75192.168.2.2311284110_defaultRoot__defaultVHost_uGenius_definst_0100192.168.0.75rtmp-rtmp://ugfms:1935/uGeniusrtmp://ugfms:1935/uGenius--WIN 11,7,700,169470211123486085975930733073normal------------------------------
connectsession2013-05-1516:14:20Mountain Daylight Time192.168.0.75192.168.2.2311284110_defaultRoot__defaultVHost_uGenius_definst_0200192.168.0.75rtmp-rtmp://ugfms:1935/uGeniusrtmp://ugfms:1935/uGenius--WIN 11,7,700,169470211123486085975930733073normal------------------------------
playstream2013-05-1516:14:20Mountain Daylight Time719_Client192.168.2.2311284110_defaultRoot__defaultVHost_uGenius_definst_0200192.168.0.75rtmp-rtmp://ugfms:1935/uGeniusrtmp://ugfms:1935/uGenius--WIN 11,7,700,169470211123486085975932483704normal719_Client--rtmp://ugfms:1935/uGenius/719_Clientrtmp://ugfms:1935/uGenius/719_Client-flv--0-00----2----------1-1.000000-
unpublishstream2013-05-1516:14:22Mountain Daylight Time719_Client192.168.2.2311284110_defaultRoot__defaultVHost_uGenius_definst_2200192.168.2.219rtmp-rtmp://ugfms:1935/uGeniusrtmp://ugfms:1935/uGenius--WIN 11,7,700,169470211123484408254314902119922normal719_Client--rtmp://ugfms:1935/uGenius/719_Clientrtmp://ugfms:1935/uGenius/719_Client--00--1456670---------------1-1.000000-
publishstream2013-05-1516:14:22Mountain Daylight Time719_Client192.168.2.2311284110_defaultRoot__defaultVHost_uGenius_definst_0200192.168.2.219rtmp-rtmp://ugfms:1935/uGeniusrtmp://ugfms:1935/uGenius--WIN 11,7,700,169470211123484408254314902119922normal719_Client--rtmp://ugfms:1935/uGenius/719_Clientrtmp://ugfms:1935/uGenius/719_Client--00--00---------------1-1.000000-
recordstream2013-05-1516:14:22Mountain Daylight Time719_Client192.168.2.2311284110_defaultRoot__defaultVHost_uGenius_definst_0200192.168.2.219rtmp-rtmp://ugfms:1935/uGeniusrtmp://ugfms:1935/uGenius--WIN 11,7,700,169470211123484408254314953420841normal719_Client--rtmp://ugfms:1935/uGenius/719_Clientrtmp://ugfms:1935/uGenius/719_ClientC:\Program Files\Adobe\Adobe Media Server 5\applications\uGenius\streams\_definst_\719_Client.flvflv130.000000--5130---------------1-1.000000-
unpublishstream2013-05-1516:14:28Mountain Daylight Time719_Client192.168.2.2311284110_defaultRoot__defaultVHost_uGenius_definst_6200192.168.2.219rtmp-rtmp://ugfms:1935/uGeniusrtmp://ugfms:1935/uGenius--WIN 11,7,700,1694702111234844082543670945294048normal719_Client--rtmp://ugfms:1935/uGenius/719_Clientrtmp://ugfms:1935/uGenius/719_Client--00--5218320---------------1-1.000000-
disconnectsession2013-05-1516:14:29Mountain Daylight Time192.168.2.219192.168.2.2311284110_defaultRoot__defaultVHost_uGenius_definst_9200192.168.2.219rtmp-rtmp://ugfms:1935/uGeniusrtmp://ugfms:1935/uGenius--WIN 11,7,700,1694702111234844082543671076294562normal------------------------------
stopstream2013-05-1516:14:29Mountain Daylight Time719_Client192.168.2.2311284110_defaultRoot__defaultVHost_uGenius_definst_9200192.168.0.75rtmp-rtmp://ugfms:1935/uGeniusrtmp://ugfms:1935/uGenius--WIN 11,7,700,1694702111234860859759290828672528normal719_Client--rtmp://ugfms:1935/uGenius/719_Clientrtmp://ugfms:1935/uGenius/719_Client-flv--8275-0665118-3624--2----------1-1.000000-
