jeffwebb6897
I need to create a pie with a cut out of it...
May 16, 2013 2:24 PM
I need to create a clean, crisp logo as follows:
Even though it is a transparent background, there is a white sporatic outline around the type and the circle.  I need to create one pie where the cout out portion is transparent and another where it is colored.  It took days to do just the above which is abismal.  I painted with white and used the eraser to create the cut out and used the line tool to shape up the triangular sides.  Trying to create a crisp curve at the top of the cut out has proved impossible.  Believe me... put this on a colored background and blow it up a bit and its very amateurish.
Help!
Jeff
    May 16, 2013 2:46 PM   in reply to jeffwebb6897
    You can create this pie logo using the radial raster tool (see manual on how to set its options) and then the shapebuilder tool to combine and delete the shapes.
    I don't understand the part with the white lines around text ... could you show?
    May 16, 2013 3:24 PM   in reply to jeffwebb6897
    THis happens when you save the file as a GIF, right?
    You need to select green as the background color, so the anti-aliasing can be rendered correctly.
    If you don't know the background color in advance, you can't use GIF, but must use PNG instead. It can contain alpha transparency.
    May 16, 2013 3:46 PM   in reply to jeffwebb6897
    You need to select the PNG 24 and check "transparency" of course. then everything that's transparent in the file will stay so in the PNG.
    May 16, 2013 4:39 PM   in reply to jeffwebb6897
    You're welcome, Jeff.
