Hec63
Display on IE compatibility view
May 16, 2013 2:18 PM
Tags: #display
I have a scaling problem, with compatibility view it is possible to fix the problem, but user dont know that.
is there a solution to avoid the scaling problem.
With IE8 and more
Firefox
  • kglad
    Jul 21, 2002
    May 16, 2013 4:40 PM   in reply to Hec63
    is that an index.html page embedding your swf?
    if yes, what are you html publish settings or, copy and paste your html code here.
  • kglad
    Jul 21, 2002
    May 16, 2013 9:22 PM   in reply to Hec63
    remove (or comment out) these two lines and retest:
           swfobject.createCSS("html", "height:100%; background-color: #666666;");
                swfobject.createCSS("body", "margin:0; padding:0; overflow:hidden; height:100%;");
  • kglad
    Jul 21, 2002
    May 17, 2013 6:45 AM   in reply to Hec63
    the problem is your embed code.
    either let flash publish your html page or post a link to your embedding html page (after making the above correction).
  • kglad
    Jul 21, 2002
    May 17, 2013 2:58 PM   in reply to Hec63
    what flash version is that?
  • kglad
    Jul 21, 2002
    May 17, 2013 4:10 PM   in reply to Hec63
    that's not a standard english version template.  i don't know if adobe uses a different french language html template or if you're using a problematic template.
  • kglad
    Jul 21, 2002
    May 20, 2013 6:20 AM   in reply to Hec63
    yes, this is the english standard html template:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
    <html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
        <head>
            <title>test4</title>
            <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
            <style type="text/css" media="screen">
            html, body { height:100%; background-color: #ffffff;}
            body { margin:0; padding:0; overflow:hidden; }
            #flashContent { width:100%; height:100%; }
            </style>
        </head>
        <body>
            <div id="flashContent">
                <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="550" height="400" id="test4" align="middle">
                    <param name="movie" value="test4.swf" />
                    <param name="quality" value="high" />
                    <param name="bgcolor" value="#ffffff" />
                    <param name="play" value="true" />
                    <param name="loop" value="true" />
                    <param name="wmode" value="window" />
                    <param name="scale" value="showall" />
                    <param name="menu" value="true" />
                    <param name="devicefont" value="false" />
                    <param name="salign" value="" />
                    <param name="allowScriptAccess" value="sameDomain" />
                    <!--[if !IE]>-->
                    <object type="application/x-shockwave-flash" data="test4.swf" width="550" height="400">
                    <!--<![endif]-->
                        <a href="http://www.adobe.com/go/getflash">
                            <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.g if" alt="Get Adobe Flash player" />
                        </a>
                    <!--[if !IE]>-->
                    </object>
                    <!--<![endif]-->
                </object>
            </div>
        </body>
    </html>
  • kglad
    Jul 21, 2002
    May 20, 2013 8:13 AM   in reply to Hec63
    change wmode to "direct" to use stage3d.
  • kglad
    Jul 21, 2002
    May 20, 2013 12:27 PM   in reply to Hec63
    no, you would use the same (standard) html template but on the html publish setting's panel, select window mode: direct.
