Lighting Effects
May 16, 2013 4:44 PM
Tags: #cs5
Lighting Effects are missing from my CS5 Program.  I go to Filters/Render/and "Lighting Effects" is not there.  Not even in Gray.  I havea copy of CS3 on my computer and the Light Effects show up in thatProgram.  Does anyone have an idea of what I can do.
    May 16, 2013 5:58 PM   in reply to Scienceednow
    What operating system are you using?
    In 64-bit versions of Mac OS with photoshop cs5, Filter>Render>Lighting Effects is only available if you run photoshop cs5 in the 32 bit mode.
    May 18, 2013 2:03 PM   in reply to Scienceednow
    Before launching the application, do a Get Info (Command+I) on the Photoshop application in the Finder:
    May 18, 2013 11:50 PM   in reply to Scienceednow
    You are not getting "the same display" because you are not following my instructions in post #4, which were to "do a Get Info (Command+I) on the Photoshop application in the Finder".
    Instead you are selecting the freaking FOLDER icon that contains the Photoshop application icon inside:
    Open that freaking folder and select the Photoshop APPLICATION ICON inside that freaking folder.  Now select the application icon inside and do a Get Info on it (Command+I):
    …and there you are!
    Applications icons look different from folder icons.
    Hope you got it now.
    May 19, 2013 1:40 PM   in reply to Scienceednow
    Glad to hear it—and you're most welcome.
