jjk23
Please help with audio and video not syncing.
May 16, 2013 4:52 PM
I'm using Encore 3, and have already authored a DVD a month ago without a glitch. The following are the same steps I used, but this time around, the video and audio in Encore are not syncing.
Here's what I've done.
1) I export my Final Cut projects to .mov using the following settings (Share > Master File).
Format: Video and Audio
Video codec: H.264
Resolution: 1920x1080
Audio file format: Quicktime Movie (AAC)
Include chapter markers: Unchecked
Roles as: Quicktime Movie
2) I run the .mov file in Compressor using the "Disc Burning" preset.
3) I then import the .ac3 and .m2v files that Compressor created into Encore.
4) In Encore, I select both files and go to New > Timeline.
In the Timeline window, the durations on both are the same. But I don't understand why the audio and video are not synced when I preview or when I burn a test DVD. The audio comes in just a tad late.
Video Clip:
Source In: 00;00;00;00
Duration: 00;02;33;29
In-Point: 00;00;00;00
Out-Point: 00;02;33;29
Audio Clip:
Duration: 00;02;34;00
Out-Point: 00;02;34;00
What's puzzling is that two of the 10 videos I've import to Encore are synced perfectly -- same export settings from FCP, same settings Compressor.
Please help.
Thanks!
Mark
    May 17, 2013 12:09 AM   in reply to jjk23
    Hi Mark.
    Do you have any situations where there is more than one video file in a timeline?
    Secondly - why are you using H264 HD files for a DVD? This is using lossy compression to make the H264, which is in turn then scaled & even further bitrate reduced for M2V.
    I would give it a try rendering an SD video file for use in Encore - not the H264 - and starting out with Dolby Digital or LPCM audio, not AAC.
    As with all DVD authoring programs, Encore works best with DVD compliant assets - which you are most definitely using - but I still think you are over-complicating things by using H264/AAC at all.
    Eliminating this may help.
