How to copy Actions over to CS6?
May 16, 2013 4:52 PM
Tags: #actions.
I just upgraded from Photoshop CS5.1 to CS6. I used the "copy presets" option during the install of CS6, which worked great for everything except my CS5.1 Actions. Is there a way to easily copy over my user-installed actions from CS5.1 to CS6? Thanks.
    May 16, 2013 5:11 PM   in reply to *Photonic
    You need to locate them in CS5.1 (whereever you saved them to) and either copy them into the CS6 actions folder or to a designated folder on your computer.
    For Windows it is usually  -
    C:\Users\username\AppData\Roaming\Adobe\Adobe Photoshop CS6\Presets
    And or
    64 bit.. C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)/Presets
    32 bit... C:\Program Files (x86)\Adobe\Adobe Photoshop CS6/Presets
    Or you can load them from any folder on your computer.
    Then load them from the actions pallet menu.
    Don't know about Mac
    May 16, 2013 6:35 PM   in reply to *Photonic
    May 16, 2013 7:53 PM   in reply to *Photonic
    I think Chris Cox has answered this many times.
    I believe if you would search the forums and check thru those posted regarding this topic, by Chris Cox if possible, of course, that you will find the answer.
    I recall that it is quite simple. I hesitate to tell you as I may say something incorrect.
    I would hold off just copying these things instinctively.
    vince
    Message was edited by: vinsolo
    May 16, 2013 8:01 PM   in reply to *Photonic
    http://www.adobe.com/cfusion/search/index.cfm?cat=support&term=importi ng%20old%20actions%20into%20new%20version&loc=en_US&self=0&lr=en_US&pr oduct=photoshop
    I believe you can copy all the actions in cs5 folder > presets > actions  to the CS6 folder > presets > actions folder. You will then use the drop down menu in the ACTIONS panel to activate those that you wish to use.
    Can't find Chris Cox posts. He is employee and maybe these are not available.
    good luck,
    vince
  • Pierre Courtejoie
    Jan 11, 2006
    May 17, 2013 7:04 AM   in reply to *Photonic
    Hello, and welcome to the forums!
    One question: were the actions saved on your hard drive, or are they just loaded in the action panel?
    In 5.1, select ane Action Set.  In the Action panel's flyout menu, select "Save actions..." and save them to the default location (given in the previous help document) (pay attention that on mountain lion, your library directory is invisible if you do not hold ALT)
    Do this for all sets.
    Now, in CS6, do Edit>Presets>Migrate presets. Is should detect and import them. Restart Photoshop, and your actions should be there. (If not, select load actions, and navigate to the 5.1 folder where you saved them)
    Photoshop CC does not require a restart, and can locate more presets...
  • Pierre Courtejoie
    Jan 11, 2006
    May 17, 2013 9:35 AM   in reply to *Photonic
    Merci for the kudos!
    I have to say that, given the schedule for me (2AM) and the relatively short amount of time to cover all that can be said on the topic, I'd like to do it record it once again, and edit out my "eems".
    Also, there are very good guides written by the Photoshop team, and there are as well many user cases, my idea is rather to point out the audience where they can find information that is relevant to them.
    That said, the Photoshop Show is a stunning idea, it's my "performance" that I feel could have been better.
