daveujn
Transitions for premiere elements10.
May 17, 2013 5:19 AM
Is there anywhere I can get a better choice of transitions for premiere elements 10?
Dave
    May 17, 2013 5:41 AM   in reply to daveujn
    You can purchase additional plug-ins from companies like Burger or NewBlue.
    http://www.burgers-transition-site.de/
    But what transition in particular are you looking for? There are dozens included with the program, all of which are customizable. And there's also the Gradient Wipe, which lets you create a wipe based on any pattern you provide.
    May 17, 2013 6:08 AM   in reply to daveujn
    Have you considered Additive Dissolve or, better, Dip to White?
    May 17, 2013 6:26 AM   in reply to daveujn
    Dave
    Have you given any thought to making your own transitions?
    What I have in mind is based on the Digital HotCakes' video tutorial "How to Use 101 Transitions" posted at its web site. I make this suggestion for informational rather than promotional reasons. I have no connection with that company. You do not have to use its assets. You can create your own and use the principles involved in the tutorial to create your unique transition.
    http://www.animationsforvideo.com/html/adobe_premiere_elements_tutori. htm#
    I will work through the idea trying to do a sample do it yourself creation if you have any interest in this aspproach.
    ATR
    May 17, 2013 6:29 AM   in reply to A.T. Romano
    And don't forget that you can customize your transitions. So you can speed up Dip to White so that it is a quick burst.
    Otherwise, do you have a YouTube link to the effect you're trying to get? You can create a custom flash transition by keyframing animation with the Lens Flare effect. You're only limited by your imagination!
    May 17, 2013 6:34 AM   in reply to Steve Grisetti
    SG
    Did you really want to address
    that to Dave?
    ATR
    May 18, 2013 6:48 AM   in reply to daveujn
    Dave,
    I think that you rushed to judgment on those FilmImpact transitions that you say that you would like but are not compatible with Premiere Elements 10. Not so for my Premiere Elements 10 Windows as well as Premiere Elements 11 Windows. This is what I did.
    1. Downloadeded "Transition Pack 1 Demo" from that link that you provided for your transitions sought list. Unzipped it with 7-Zip.
    2. Took the Impact_Flash.prm from that and placed it in my Windows 7 64 bit, using the path:
    Local Disk C
    Program Files
    Adobe Premiere Elements 10
    Plug-Ins
    Common
    and in the Common Folder placed this .prm file.
    When I opened Premiere Elements 10 project, Edit Header/Transitions/Video Transitions/, I found the "Impact Flash" transition there in a category named "FilmImpact.net 1". From there I dragged the transition to the Timeline where it worked well at playback of my rendered Timeline in the Edit Mode monitor.
    3. The same was true for Premiere Elements 11. Installation route was the same except the folder "Adobe Premiere Elements 11" replaced "Adobe Premiere Elements 10" in the path.
    When I opened Premiere Elements 11 project, went to the Transition Tab at the bottom of the Expert view interface, I found the "Impact Flash" transition under the category named "FilmImpact.net 1". Worked great when dragged to Timeline Expert view.
    That was only one of the downloaded .prm transitions that I tested. You may want to take another look at the compatibility of these specific transitions in your system if you want the free ones and are willing to pay for the others in that download that are not free, just there as demos.
    Please update us on your progress.
    Thanks.
    ATR.
