HDS-Live playback stops after some time
May 17, 2013 9:42 AM
Hi all,
I've got a problem with the HDS-Live setup using ams 5 and OSMF 2.0. after few minutes (different intervall all the time) player stops playback and doesn't continue. In the chrome's network connection panel I see that player requests only Bootstrap files and not the actual segments any more. Even if I wait for 5 minutes segments don't get requested and playback doesn't continue.
Anyone had similar problem, or know of any solution?
    May 27, 2013 12:23 AM   in reply to Xrtili7
    Hi
    When the playback stops, do you see a 304 being returned for a bootstrap?
    -Karishma
    Jun 17, 2013 1:16 PM   in reply to Xrtili7
    I had a similar problem and it turned out that I had to delete the files created on the server after every live stream.
    Go to <Application folder>\applications\livepkgr\streams\_definst_\livestream and delete all the files in this folder.  If you are using a different stream name than livestream the go to that folder.  I came across a document from adobe that said that when a HDS-Live stream end is does not delete the dynamically created files and each time you start a new live stream if you do not delete the previous files you will get behavior like this.
    Dec 10, 2013 9:42 PM   in reply to Xrtili7
    Hi, Xrtili7
    Can you share your cache parameters for reference, thank you very much.
    Dec 17, 2013 8:42 AM   in reply to YoungJ
    The cache parameters are the default setting set during installation of AMS 5
