JoeyJojoII
Problem with getting font name in PS CS5/CS6 plugin
May 18, 2013 12:10 PM
Tags: #plugin #sdk #font_name #fontname #getstring
Hello,
When I call GetString method such as:
error = sPSActionDescriptor->GetString(descFont, keyFontName, fontName, stringLength);
on some .psd file which contains text layer(s), I get error -1715.
Weirdly, this doesn't occure on all versions of Photoshop, for example I created a file in PS CS5, and this error occurs both in CS4 and CS6, but it works fine in CS5.
If anyone could tell me why this is happening, I would be really grateful.
Thank you!
    Jun 11, 2013 12:58 PM   in reply to JoeyJojoII
    Your layer probably has a layer style.
    Try this script and see if it gets your font information for you. You will need to convert to C/C++ of course but see if this script can find your font on the document.
    var fontsInUse = [];
    var colorsInUse = [];
    if ( documents.length > 0 ) {
        GetFontUsage( activeDocument.layers, fontsInUse );
              alert( fontsInUse );
        GetColorUsage( activeDocument.layers, colorsInUse );
              alert( colorsInUse );
    } else {
              alert( "Please open a document." );
    function GetFontUsage( l, f ) {
        for ( var i = 0; i < l.length; i++ ) {
            if ( l[i].typename == "LayerSet" ) {
                GetFontUsage( l[i].layers, f );
            } else if ( l[i].typename == "ArtLayer" && l[i].kind == LayerKind.TEXT  ) {
                try {
                    f.push( l[i].textItem.font );
                catch(e) {
                    f.push( GetFontUsageFromDescriptor( l[i] ) );
    function GetColorUsage( l, f ) {
                try {
                    f.push( Math.round(l[i].textItem.color.rgb.red) + ":" +
                            Math.round(l[i].textItem.color.rgb.green) + ":" +
                            Math.round(l[i].textItem.color.rgb.blue));
                catch(e) {
                    f.push( GetColorUsageFromDescriptor( l[i] ) );
    // text layer probably has a layer style
    // we will try to select the layer
    // pull the descriptor
    // and see if we can find a font
    function GetFontUsageFromDescriptor( l ) {
        var layerFontName = "";
        var lastActive = activeDocument.activeLayer;
        activeDocument.activeLayer = l;
        var ktextKeyStr = stringIDToTypeID("textKey");
              var ref = new ActionReference();
              ref.putProperty(charIDToTypeID('Prpr'), ktextKeyStr);
              ref.putEnumerated(charIDToTypeID('Lyr '), charIDToTypeID('Ordn'),
        char IDToTypeID('Trgt'));
              var desc = executeActionGet(ref);
              if ( desc.hasKey( ktextKeyStr ) ) {
                        var descText = desc.getObjectValue( ktextKeyStr );
            var kparagraphStyleRangeStr = stringIDToTypeID( "paragraphStyleRange" );
            if ( descText.hasKey( kparagraphStyleRangeStr ) ) {
                var paraList = descText.getList(  kparagraphStyleRangeStr );
                var kparagraphStyleStr = stringIDToTypeID("paragraphStyle");
                var paraDesc = paraList.getObjectValue( 0 );
                if ( paraDesc.hasKey( kparagraphStyleStr ) ) {
                    var paraStyle = paraDesc.getObjectValue( kparagraphStyleStr );
                    var kdefaultStyleStr = stringIDToTypeID("defaultStyle");
                    if ( paraStyle.hasKey( kdefaultStyleStr ) ) {
                        var defStyle = paraStyle.getObjectValue( kdefaultStyleStr );
                        var kfontPostScriptNameStr = stringIDToTypeID("fontPostScriptName");
                        if ( defStyle.hasKey( kfontPostScriptNameStr ) ) {
                            layerFontName = defStyle.getString( kfontPostScriptNameStr );
        activeDocument.activeLayer = lastActive;
        return layerFontName;
    // and see if we can find a color
    function GetColorUsageFromDescriptor( l ) {
        var layerColor = "";
                        var kColorStr = stringIDToTypeID("color");
                        if ( defStyle.hasKey( kColorStr ) ) {
                            var colorDesc = defStyle.getObjectValue( kColorStr );
                            layerColor += Math.round( colorDesc.getInteger( stringIDToTypeID("red" ) ) ) + ":";
                            layerColor += Math.round( colorDesc.getInteger( stringIDToTypeID("green" ) ) ) + ":";
                            layerColor += Math.round( colorDesc.getInteger( stringIDToTypeID("blue" ) ) );
        return layerColor;
