Need to merge multiple tracks down to avoid choppy playback.
May 18, 2013 3:31 PM
I have Adobe Premier Elements 9.  I'm creating a music video from several takes recorded over a couple of hours, and have started lining the different tracks one on top of the other.  I find that by the third track, even with a 6 core processor and 8 GB of memory, that the playback is so choppy as to be unworkable.  I know I can Render the Timeline to get a smooth flow again, but as soon as I change one little piece it again becomes insanely choppy.  I thought I saw a way to merge the tracks down, but now I can't find how to do that, and I'm not even sure that that's the best solution to the problem.  Any suggestions?
    May 18, 2013 3:57 PM   in reply to pdbrownphotographer
    pdbrownphotographer
    I am not 100% clear on what you intend with "merge down". Are you talking about moving the contents of, for example, Video 3 to 2, something like that or something else?
    You can select a group of clips by drawing a rectangle around the clips with the mouse cursor and then using the mouse cursor to move the highlighted group to a new location. Is that what you had in mind?
    As for your computer resources...your Premiere Elements 9.0/9.0.1 is a 32 bit application running in the 32 bit compatibility mode of a 64 bit system and as such has the liabilities of 32 bit system, namely, maximum supported installed RAM = 4.0 GB with 3.0 GB or less of that available. Premiere Elements 10 and 11 become 64 bit applications when they are run on Windows 7 or 8 64 bit computer, thus affording them more resources of 64 bit system.
    Please evaluate your available RAM and free hard drive situation when the choppy problems set in. Is your computer optimized?
    More details of the project will probably be needed to get at the core of the matter if the issue goes beyond compromised computer resources.
    Thanks.
    ATR
    May 18, 2013 7:49 PM   in reply to pdbrownphotographer
    pdbrownphotographer
    Thanks for the follow up. First let us see if we can find Premiere Elements 11.
    1. Have you gone to Control Panel/Programs/Uninstall A Program and looked through the list of installed programs, searching for Premiere Elements 11 which should have a file size of about 1.23 GB. If it is not there, it is not installed.
    2. If you do see it in the Control Panel area just described, then close out of there and head for
    Local Disk C
    Program Files, not Program Files (x86)...assuming a Windows 7 or 8 64 bit computer
    Adobe
    Premiere Elements 11 (is it there?)
    If it is, then look for the Adobe Premiere Elements.exe file and create a desktop shortcut for it. DO NOT SELECT Adobe Premiere Elements 11.exe.
    If not, when you were installing it, did you ask for a different save location for it other the Adobe default? If not, as it progressed in the installation, did you watch it progress from beginning to end. Was there ever any evidence that somewhere along the line the install stopped and rolled back?
    When you installed the download, did you disable the firewalls and antivirus?
    Depending on how things go,
    a. make sure there are no signs of Premiere Elements 11 installed. Put the Premiere Elements 11 installation files in a safe place.
    b. use ccleaner on your computer, both regular and registry type
    http://www.piriform.com/ccleaner
    c. When you feel confident that the computer is as optimized as possible, then try to install Premiere Elements 11.
    We will be watching for your progress. Depending on your results, we will think about what next after you report back with the results.
    Thanks.
    ATR
    May 18, 2013 8:56 PM   in reply to pdbrownphotographer
    pdbrownphotographer
    Did you notice any irregularies in the downloading process?
    The ccleaner (registry section) should clean out any leftovers from prior incomplete installs/uninstalls. Just say yes when it asks if you want to backup registry before the clean up. Nothing is a 100% guarantee, but I have used ccleaner registry cleaner many times without problems.
    Do you have the latest version of QuickTime installed on your computer? If you have Premiere Elements 9.0/9.0.1, I assume that you have? Besides the firewalls, antivirus, please check out permissions and User Accounts with Administrative Privileges.
    We will be watching for your progress tomorrow morning. Do not give up.
    Thanks.
    ATR
    May 18, 2013 9:25 PM   in reply to pdbrownphotographer
    pdbrownphotographer
    Just about to close computer. It is after midnight where I am.
    Just this thought for when I check your thread in the light of day.
    a. In the download process, were you asked to download the Adobe Download Assistant? If so, did you?
    More in the light of day.
    ATR.
    May 19, 2013 7:49 PM   in reply to pdbrownphotographer
    pdbrownphotographer
    It is getting to that time of night again, and I am just getting to post my thoughts on your thread.
    1. Have there been any breakthroughs in getting Premiere Elements 11 installed on your computer so that it shows up in the Control Panel area for installed programs? Premiere Elements 11 as a 64 bit application on Windows 7 64 bit might be the answer to gaining more resources for your video editing project. But, keep in mind, that Premiere Elements' Timeline content with orange line over it is the program telling you that you are not viewing the best possible preview in the Edit Mode Monitor. Render. This is a preview thing. You do not have to do it. But it is your window of opportunity to catch a problem sooner than later. It becomes essential when it comes to titles, effects, transition, and non native format video. The concept is common to Premiere Elements any version.
    2. As for your workflow, have you given any thought to the classical approach to working with the larger project in smaller pieces of it. If you use this concept, you would work segments of your grand project in several separate smaller projects, exporting each of the smaller project's Timeline content to an appropriate file type saved to the computer hard drive.. Then you would unite these exports into one grand project for the final product. I do not recall seeing your Premiere Elements 9.0/9.0.1 project settings for your present setup. If you want to consider this idea, please supply the information, and I will offer more specific how to details.
    Thanks.
    ATR
    May 21, 2013 7:23 AM   in reply to pdbrownphotographer
    pdbrownphotographer
    You wrote:
    Interesting idea on the splitting the project up.  So far I'm working on music videos, so they're only 3-4 minutes long, not a lot to split.  But I realize I can still save chunks of work that way as well to effectively merge multiple tracks into one.  I was afraid of having compression problems if I did that, so I want to save in an uncompressed format.  Is DV NTSC uncompressed, or would MS AVI be better?
    There is no NTSC DV AVI uncompressed. DV is the compression, and .avi is the wrapper format that wraps the video and audio compressions. All video undergo degradation with re-encoding, but DV AVI appears to fare better in that regard than others. For that reason and others, it is preferred. If an uncompressed .avi is wanted for whatever reason, typically the recommended route is (in your case) Share/Computer/AVI with Presets = Microsoft AVI and the video codec = None under the Advanced Button/Video Tab of the preset.
    But, a just in case note, even if you start with a Presets setting of "DV NTSC....." in Share/Computer/AVI route and even if you go into Advanced Tab/Video Tab there and change the video codec to Microsoft AVI, you no longer have DV NTSC and are replacing DV with something else.
    If you have your computer optimized, then best we take a deeper look into the project settings as well as the export choices to see if we can get any choppy display from YouTube.
    Looing forward to your results.
    Thanks.
    ATR
    May 21, 2013 8:07 AM   in reply to pdbrownphotographer
    ATR has explained the DV-AVI (NTSC in your case) vs AVI [uncompressed] very well. The compression rate for DV-AVI is about 5%, so it maintains quality, even with multi-generational material. It also plays very well on a PC, and if one has Flip4Mac on their Mac, will also play well. I typify it as being "plain vanilla," and is basically the format/CODEC, around which, PrE is built.
    If I have several "round-trips," say between PrE and another program, i.e. multi-generational, I will often use one of the Lossless CODEC's, such as Lagarith, or UT. While they DO compress a bit, they are visually lossless. The upside is they allow for the exact same quality, but with some compression, and they are free. The downside is that one MUST download and install them onto every computer, that will handle the material. Many users fell that they are not worth the effort to download and install, and that they are not easily shared, because all other computers need the CODEC's, but I like using them. More info here: http://forums.adobe.com/message/4556586#4556586
    Now for your Fade In/Fade Out issue. If you are having problems applying what is basically a Preset, you can instead create the Fade In, and Fade Out by hand. Probably the easiest way is to just Keyframe the Fixed Opacity Effect (automatically applied to every Video Clip by PrE) over time. Starting with an Opacity of 0 (black) and progressing straight-line to 100 (completely visible), will give you the Fade In. Repeat, but in the reverse order, 100 - 0, at the Tail of Clip, will give you a Fade Out. Personally, I seldom use those Presets, since I have even more control (one can change the Interpolation, as desired) with Keyframes, and they are so very easy. Steve Grisetti has a great tutorial at Muvipix.com on Basic Keyframing, if needed.
    May 21, 2013 8:18 AM   in reply to pdbrownphotographer
    pdbrownphotographer
    Oops.
    I just read Hunt's helpful suggestions and realized that I left out comments directed to your question about FadeIn and FadeOut.
    Besides his comments, I would have these questions:
    a. How are you trying to apply the FadeIn FadeOut.....Are you right clicking the clip, selecting the Fade option from the pop up or are you highlighting the clip, going to its Properties Palette/Opacity Panel and using the FadeIn and FadeOut there?
    b. For you, does it make a different which location that you use (if you are using "a" above)?
    Thanks.
    ATR
    May 22, 2013 8:20 AM   in reply to pdbrownphotographer
    pdbrownphotographer
    Thanks for the follow up with the great news that you have downloaded and installed Premiere Elements 11, and you are moving forward on evaluating the program. It was not clear to me what the key was to getting that Premiere Elements 11 to download for you. What do you think was the key step that resulted in success?
    Glad you found the suggestions in this thread helpful.
    Continued success and please do not hesitate to ask questions or ask for clarification on anything written.
    Thanks again.
    ATR
    May 23, 2013 6:36 AM   in reply to pdbrownphotographer
    pdbrownphotographer
    Thanks for the follow up with the great news of your Premiere Elements successes.
    True, the Shuttle is only in the Full Screen in Premiere Elements 11 Windows (assumed Mac as well, but not sure since I do not have Mac computer). I think that was question was brought up in a thread here only the other day.
    As for Premiere Elements 10, Adobe direct is only selling the latest version Premiere Elements 11 and only is offering the tryout version of Premiere Elements 11. But Premiere Elements 10 can still be purchased from online source (looks like limited supply as of this writing).
    As far as I have figured out, that Creative Cloud and its subscription aspects do not apply to Premiere Elements. Have you been reading
    http://www.adobe.com/education.edu.html?showEduReq=no
    You can check with Adobe Marketing, but Premiere Elements is no part of that Photoshop crowd in the Clouds.
    Great progress. Keep up the good work.
    ATR
    May 23, 2013 7:34 AM   in reply to pdbrownphotographer
    If you do decide to go the PrPro route, CS 6 has reached the end of its lifespan. Adobe stopped selling the physical media some time back, but still offers some of CS 6 (several suites of programs) as download. However, the full roll-out of the CC (Creative Cloud) for all of those programs, PrPro, Ps, AI, After Effects, etc. (not either PsE, or PrE) is slated for June 15th, and probably around that point, there will be no CS 6 download, with pertetual license - only CC. There were a few of the boxed, physical media packages available from certified resellers, but one had better hurry - when those are gone, there will be no more.
    May 23, 2013 9:35 AM   in reply to pdbrownphotographer
    I am also not a fan of the CC (Creative Cloud) licensing concept - at least not yet.
    I feel that my timing was good, when I upgraded from CS 5.5 Production Suite to CS 6 Production Suite.
    There are still some Bugs with CS 6, that were not in CS 5.5, and I fear that since CS 6 has reached the end of its life, Adobe will never address those. Right now, they do not affect me, or my Projects, and if they do, then I can do those Projects in CS 5.5.
    Only time will tell whether I am adequately tempted to go with PrPro CC (actually the full Production Suite).
    Between you and me, I really like editing in PrPro, and basically only have PrE installed, to test problems in this program. However, from time to time, I force myself to use PrE, to stay somewhat current in it. Just did my first ever DVD output, completely from PrE 11. As I am so used to PrPro and Encore for that type of output, I struggled a bit, but needed to do it, to know what others encounter. For larger, more intense Projects, I would not give up my PrPro, AE and Encore - no more than I would give up my Photoshop for Photoshop Elements. Just my personal preferences, and I admit that I recommend PrE and PsE more than PrPro and Ps, for most users - they do not need to power of the two "big-brothers," and can save a boatload of $, by sticking with the Elements programs.
    Good luck, and please let us know how things progress.
    BTW - you mentioned some Audio aspects, and PrPro CS 6 has made some major changes in how Audio is handled. I strongly recommend the AdobeTV episodes on Audio in PrPro CS 6, and also Audition CS 6. Some very, very useful changes.
