OldTrucker049
after effects warning: failed to create script panel
May 18, 2013 6:50 PM
Can anyone help me out? Every time I try and load a script I get this warning "after effects warning: failed to create script panel"
I am using CS6
OS NameMicrosoft Windows 7 Professional
Version6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS ManufacturerMicrosoft Corporation
System Name
System ManufacturerINTEL_
System ModelDH55HC__
System Typex64-based PC
ProcessorIntel(R) Core(TM) i3 CPU     540  @ 3.07GHz, 3059 Mhz, 2 Core(s), 4 Logical Processor(s)
BIOS Version/DateIntel Corp. TCIBX10H.86A.0037.2010.0614.1712, 6/14/2010
SMBIOS Version2.6
Windows DirectoryC:\Windows
System DirectoryC:\Windows\system32
Boot Device\Device\HarddiskVolume2
LocaleUnited States
Hardware Abstraction LayerVersion = "6.1.7601.17514"
User Name
Time ZoneEastern Daylight Time
Installed Physical Memory (RAM)16.0 GB
Total Physical Memory15.9 GB
Available Physical Memory12.3 GB
Total Virtual Memory31.7 GB
Available Virtual Memory27.9 GB
Page File Space15.9 GB
Page FileC:\pagefile.sys
Any help would be great
    May 18, 2013 11:09 PM   in reply to OldTrucker049
    Well, what script? Did you install it properly?
    Mylenium
    Jun 6, 2013 1:38 AM   in reply to OldTrucker049
    I have had this problem also with CS6 and found a solution.  If I try to open a script UI panel with a project open, I get this message, but if I close the project and then launch the scripts, they write without hassle.  Then I re-open my project.  Hope that helps.
    Mandy
