wonmanfactory
Premiere Pro output/export is blurry
May 20, 2013 12:53 PM
Tags: #degraded_video #blurry_image
Hello, I have never got much luck editing desktop videos with premiere pro. It seems it can only deal with Video Camera shot footage but not computer generated videosCapture.PNG
I have captured my computer screen using FFMPEG and imported my footage to premiere pro. Look at the left hand side source monitor, how clear is the image and right hand side program monitor, image is blurry and color is poor. Not only does it happen in playback, in the export, there is no difference.
And by my previous experience, premiere titles tend to get blurry. It doesn't render properly its own elements. When I select "Match Sequence Settings" when I export, the blur seem to have gone away.
My sequence setting is as shown: Editing Mode is Desktop
When i edit it in After Effects, it seems no problem. Have I done anything wrong?
    May 20, 2013 2:20 PM   in reply to wonmanfactory
    Screen capture software often/usually creates video that is hard to edit... below are some saved links discussing other software... some of the ideas may help you
    Some of these are for Premiere Elements, but may help with PPro
    Fraps & Elements http://forums.adobe.com/thread/871095
    -and more Elements http://forums.adobe.com/thread/943772
    -and yet more Elements http://forums.adobe.com/thread/967201
    Camtasia http://forums.adobe.com/thread/836800
    -and http://forums.adobe.com/thread/775288
    -and http://forums.adobe.com/thread/453044
    -and http://forums.adobe.com/message/3202148
    Techsmith codec http://forums.adobe.com/message/3692768
    -and http://forums.adobe.com/thread/1046914?tstart=0
    BB Flashback http://forums.adobe.com/thread/1074014
    XSplit recorder http://forums.adobe.com/thread/1160940
    Elgato http://forums.adobe.com/thread/1163126 w/picture
    Dxtory http://forums.adobe.com/message/5172056
    Bandicam read #10 http://forums.adobe.com/thread/954394
    May 20, 2013 5:30 PM   in reply to wonmanfactory
    It is designed around standardized camera formats.  Unfortunately, few if any screen capture programs will allow you to record to those formats, so issues do crop up.
    May 21, 2013 2:48 AM   in reply to wonmanfactory
    Definitely NOT!
    Premiere can handle 4:4:4 uncompressed footage pixel by pixel in 10Bit Colors or more if you need.
    Something goes completely wrong with your setup...
    1. You have a PAL sequence with 720x576 pixels - I don't think that is the resolution of your computer monitor? --> Set the sequence to the native res. of your screen grabs.
    2. I see al lot of MPG Video in your bin - I assume that it's 4:2:0 colr smaples MPEG video - bad idea to encode sharp red computer typeo this way... export to DPX files and see the difference
    3. Set your sequence to Maximum Render Quality to get better pixel sampling (use GPU mode to speed up things)
    If you take the right settings you won't see any difference to your source footage. More challanging would be to find good export settings for H.264 video - because there you have to deal with the 4:2:0 color smapling again... a dedicated screencast codec could help here...
    May 21, 2013 5:53 AM   in reply to nw42
    To add to what mw42 told you, it looks like you captured at 29.97fps (NTSC) and are exporting at 25fps (PAL).
    I don't know anything about FFMPEG. However, I capture using a free program called Camstudio-Recorder. I capture to the Lagarith Lossless Codec and it comes out extremely sharp. (With large files - you have been warned)
    Remember to size your window before you capture it, that way Premiere Pro will not have to do that. Then, create your sequence carefully. In my case, my captures are very seldom exactly 1920X1080 because that is the maximum size it could be on my monitor and most windows have a border I do not want.
    So I set up a 1920X1080 sequence manually. Just be careful to match the frames per second as well. Then do not scale the video. Just allow the black bars when you use the Vimeo or YouTube presets for your export. Or, with a little practice you can scale your windows to exactly 1280X720 and capture that.
    There is no need to edit in desktop mode anymore. Not in CS6 anyway.
    Sorry this is so big a screen capture, but I wanted you to see how clear the text is. I capture the video as described above.
