3D menu greyed out in Photoshop CS6
May 20, 2013 1:01 PM
I am running windows 7 64-bit
Photoshop CS6 extended via Creative Cloud
Graphics Card: NVIDIA Quadro NVS 420
Latest driver: version 320.00
When trying to access the 3D menu in Photoshop it is greyed-out. The only item selectable is 'Get More Content'
Any suggestions?
Phil
  • Pierre Courtejoie
    Jan 11, 2006
    May 20, 2013 2:10 PM   in reply to philking
    Hello! According to http://helpx.adobe.com/photoshop/kb/photoshop-cs6-gpu-faq.html, your video card is supported. The videeocard needs to have 512 MB to give you access to the 3D tools.
    could you please post the contents of help> system info so that we can see what the
    GPU sniffer reports?
    May 21, 2013 5:36 AM   in reply to philking
    Video Card Memory: 256 MB
    Ps 13.1.2 is programmed to not enable 3D when VRAM is less than 512 MB.
    In case you want to try 13.0.1, it allows me to use 3D with 256 MB although 512 MB is the stated requirement.
  • Pierre Courtejoie
    Jan 11, 2006
    May 21, 2013 5:37 AM   in reply to philking
    Unfortunately, your videocard does not have enough RAM to support the 3D features.
    Also, I notice that you are running the 32bits version of Photoshop. You would have more RAM available if you were using the other installed version, with (64bits) appended (but it would not fix your 3D issue).
    May 21, 2013 5:54 AM   in reply to philking
    As I already said,
    May 21, 2013 10:42 AM   in reply to philking
    Note that the VRAM limit was increased to avoid frequent bugs in video card drivers.
    The limit should have been 512 Meg to start with.
    Jan 13, 2014 10:32 AM   in reply to philking
    Just a quick question which may answer your problem.  What is your file set to: RGB or CMYK.  If set to CMYK, it will grey out all of your 3D menu options.
    Mar 18, 2014 2:53 PM   in reply to Baaine
    THANK YOU, BAAINE!!! i've been having the same problem with my 3d tool menu greyed out and spent so much time perusing the web and the other posts in this thread. your simple post and solution of switching to RGB from CMYK values resolved my problem. now why couldnt the other dudes have thought of that earlier?? sometimes its the smallest solution that fixes the problem!!
