Why does the 'publish preview' screen in flash cs5 show part of the animation and then turns blank?
May 21, 2013 3:04 AM
Tags: #cs5.5 #bug #animation #flash_cs5.5_crashing
Hi I am creating frame by frame animation in photoshop.
I am importing the photoshop files into flash using
FILE > IMPORT > IMPORT TO STAGE
I used to be able to preview or "line test" my animation easily by clicking on:
FILE > PUBLISH PREVIEW > FLASH
I could watch the animation loop and see where improvements are needed. Now, flash struggles a lot with the files, takes a long time to load the preview, when it finally does, it shows me maybe a third of the animation, turns blank, and acts as if all my frames are completely blank. I cannot later see them on my main work surface either.
Does anyone know what is going on? I keep restarting flash but the same problem persists.
Thanks in advance for any help or suggestions
  • kglad
    Jul 21, 2002
    May 21, 2013 4:20 AM   in reply to weronika_w
    how many frames in your swf?
    how large is your swf?
  • kglad
    Jul 21, 2002
    May 21, 2013 5:49 AM   in reply to weronika_w
    that's over 100megs of images so you are probably hitting a flash cs5/system limit.
    are you using an alpha channel and layering some of these images over one another?
  • kglad
    Jul 21, 2002
    May 21, 2013 9:16 AM   in reply to weronika_w
    is there some reason you cannot use vectors for your animation?
    vector animation is one of flash'es strong points.
