blueskyfree1
How do you format text into columns?
May 21, 2013 5:30 AM
Hello,
I would like to format text into 3 separate columns using css.
Thanks.
    May 21, 2013 5:41 AM   in reply to blueskyfree1
    May 21, 2013 5:43 AM   in reply to blueskyfree1
    How you would do this will depend on what it is you want to achieve with those three columns.
    The easiest way would be to have three floated left (or right) containers, e.g.,
    <style type="text/css">
    .column {
    width:250px;
    float:left;
    margin-right:15px;
    .column + .column + .column {
    margin-right:0;
    </style>
    <div class="column">
    <p>This is column1</p>
    </div>
    <p>This is column2</p>
    </div>
    <p>This is column3</p>
    </div>
    May 21, 2013 5:55 AM   in reply to blueskyfree1
    For example:
    div {
            width: 900px;
            -moz-column-count: 3;
            -webkit-column-count: 3;
            column-count: 3;
    There are many other related CSS properties column-width, column-gap, column-rule, etc http://www.w3.org/TR/css3-multicol/
    (This can also be done using Javascript and that will work on all browsers unlike CSS above.)
    Kenneth Kawamoto
    http://www.materiaprima.co.uk/
    May 21, 2013 6:18 AM   in reply to kennethkawamoto2
    I have tested this on my systems and found it degrades gracefully in IE10 & Opera 12.15. Looks ok in Safari, Chrome and FF.
    May 21, 2013 6:29 AM   in reply to blueskyfree1
    With which method? The CSS-only method has options specified on the link Kenneth posted. The CSS/HTML method that I posted would allow you to do that just by editing the CSS widths, e.g.
    .column {
    width:20%;
    float:left;
    .column + .column {
    width:60%
    width:20%;
    </style>
    The real difference is that in my method, you must populate each of the columns manually. In the CSS-only method, the columns are created and formed automatically from a single stream of text.
