Ed Davis1999
Edit Font in Text Field in Acrobat X Pro
May 21, 2013 9:43 AM
I have a PDF that was created and I need to change the font in a text field.  I am using Acrobat X Pro and I have been unable to get the typewritter to become active and have not found a way to change the font in this text field.
    May 21, 2013 10:56 AM   in reply to Ed Davis1999
    If it's a real text field go to Tools - Forms - Edit, then right-click the
    field and select Properties. Go to the Appearance tab and you'll be able to
    change the font used in it.
    May 21, 2013 1:15 PM   in reply to Gilad D (try67)
    If it is document text (not really a text field), then use the text edit tool. Select the text and right click to change the font -- has to be compatible with the font that was used when creating the document).
