"Select same fill & stroke" etc. isn't working in CS6
May 22, 2013 4:37 AM
Select same fill and stroke, or select same fill is not working properly in my newly installed version of CS6.
This is happening across multiple files so I know it is not a corruption in a file causing it.
When I make a selection and then click "Select same fill" I get the questioned marked swatch indicators.
This appears to be a bug in the software because I cannot make this feature work on even a simple file.
Any ideas??
Screenshot attached to show what I am seeing when I try to select a single piece of outlined type and then use the "select same fill" option.
Thanks in advance. I can work around this by selecting elements individually, but I would rather not!
    May 22, 2013 5:32 AM   in reply to Rebekkah Angel
    Rebekkah,
    It sounds as if something is seriously wrong.
    You may try the following (you may have tried/done some of them already) and see whether it helps:
    1) Close down Illy and open again;
    2) Restart the computer;
    3) Close down Illy and press Ctrl+Alt+Shift/Cmd+Option+Shift during startup (irreversible);
    4) Move the folder with Illy closed (reversible);
    5) Look through and try out the relevant among the Other options, see especially Item 7;
    Even more seriously, you may:
    6) Uninstall, run the Cleaner Tool, and reinstall.
    http://www.adobe.com/support/contact/cscleanertool.html
    May 22, 2013 5:37 AM   in reply to Rebekkah Angel
    You are welcome, Rebekkah.
    I hope you will post your findings; it may benefit others in distress.
    May 22, 2013 6:58 AM   in reply to Rebekkah Angel
    Could you post one of these "simple" files somewhere?
    May 22, 2013 7:59 AM   in reply to Rebekkah Angel
    That sounds like a good solution, Rebekkah.
    Thank you for sharing.
    It is far from unusual that files must be withheld.
