How to recolor artwork from blacks to reflex blue?
May 22, 2013 4:37 AM
The recolor needs to change the artwork from blacks/whites/grays to reflex blue + tones
tnx
    May 22, 2013 6:54 AM   in reply to gaxfwind
    And what is it exactly you are having problems with that you can't do with a simple brightnes based gradient or a pre-defined set of swatches? You need to clarify and explain better. simply sounds liek you have never used the tool or even read the help...
    Mylenium
    May 22, 2013 7:06 AM   in reply to gaxfwind
    German user interface, but should work for you. Just click on the same button according to the layout of stuff on the screen:
    http://vektorgarten.de/img/tut/schwarzinpantone.mov
    May 22, 2013 7:16 AM   in reply to gaxfwind
    1. Clear swatches pallete of all colors but relfex blue
    2. Select all artwork to be recolored
    3. Edit >> Edit Colors >> Recolor Artwork with preset >> 1 color
    4. Library >> Document Swatches
    May 22, 2013 11:56 AM   in reply to gaxfwind
    Which version of Illustrator are you using ?
    May 23, 2013 3:18 AM   in reply to gaxfwind
    Gadi,
    You may try to use the grayscale image for an Opacity Mask and see whether that is satisfactory as an additional masure. You may:
    1) Create a larger reflex blue rectangle beneath the image;
    2) Select both and in the Transparency palette flyout tick Make Opacity Mask, with Clip and Invert Mask ticked.
    May 23, 2013 8:15 AM   in reply to gaxfwind
    If the image is  a grayscale tif colored in illustrator then recolor artwork should correct this.
    Otherwise you will can in Photohsop resave this as a grayscale tif, replace image in illustrator, and color in illustrator using a swatch of reflxe blue.
    Alterantively you could change the grayscale image in photshop to a monotone, and choose Reflex blue.
