Farhad Navaei
Dynamically adding ColumnSeries doesn't work
May 22, 2013 11:24 AM
Tags: #flex #4.5 #actionscript #charting
I created the following code to create different series dynamically:
        creationComplete="application1_creationCompleteHandler(event)"
        xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
        <fx:Script><![CDATA[
            import mx.charts.series.ColumnSeries;
            import mx.collections.ArrayCollection;
            import mx.collections.Sort;
            import mx.collections.SortField;
            import mx.events.FlexEvent;
            [Bindable]
            public var Loc01:ArrayCollection = new ArrayCollection([
                {date:2002, close:41.87, loc: Location 01},
                {date:2005, close:48.06, loc: Location 01},
                {date:2006, close:48.06, loc: Location 01},
                {date:2002, close:157.59, loc: Location 02},
                {date:2003, close:160.3, loc: Location 02},
                {date:2003, close:45.74, loc: Location 01},
                {date:2004, close:42.77, loc: Location 01},
                {date:2004, close:150.71, loc: Location 02},
                {date:2002, close:45.74, loc: Location 03},
                {date:2003, close:42.77, loc: Location 03},
                {date:2004, close:150.71, loc: Location 03},
                {date:2005, close:156.88, loc: Location 02}
        protected function application1_creationCompleteHandler(event:FlexEvent):void
            // TODO Auto-generated method stub
            var obj:Object;
            var arr:Array = [];
            var i:int;
            var ac1:ArrayCollection;
            var NS:ColumnSeries;
            var sortA:Sort = new Sort();
            var sortByLocation:SortField = new SortField(loc,false,false,false);
            var sortByDate:SortField = new SortField(date, true, false, false);
            sortA.fields=[sortByLocation, sortByDate];
            Loc01.sort=sortA;
            Loc01.refresh();
            i=0;
            arr[i] = Loc01[0].loc;
            for each(obj in Loc01){
                if(arr[i] != obj.loc)
                    i++;
                    arr[i] = obj.loc;
            var str: String;
            i=0;
            for each(str in arr){
                ac1 = new ArrayCollection();
                    if(str == obj.loc)
                        ac1.addItem(obj);
                ac1.refresh();
                if(!myChart.series[i])
                    myChart.series.push(new ColumnSeries());
                NS = myChart.series[i];
                NS.dataProvider = ac1;
                NS.yField = close;
                NS.horizontalAxis = h1;
                NS.displayName = str;
                NS.verticalAxis = v1;
                NS.id = cs + i.toString();
                i++;
    ]]></fx:Script>
    <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
    </fx:Declarations>
    <mx:Panel x="49" y="30" width="868" title="Column Chart With Multiple Axes">
        <!--mx:Legend width="769" dataProvider="{myChart}"/-->
        <mx:ColumnChart id="myChart" width="601" showDataTips="true" dataProvider="{Loc01}">
            <mx:horizontalAxis>
                <mx:CategoryAxis id="h1" categoryField="date"/>
            </mx:horizontalAxis>
            <mx:horizontalAxisRenderers>
                <mx:AxisRenderer placement="bottom" axis="{h1}"/>
            </mx:horizontalAxisRenderers>
            <mx:verticalAxisRenderers>
                <mx:AxisRenderer placement="left" axis="{v1}"/>
            </mx:verticalAxisRenderers>
            <mx:verticalAxis>
                <mx:LinearAxis id="v1" minimum="30" maximum="170"/>
            </mx:verticalAxis>
            <mx:series>
                <mx:ColumnSeries id="cs0"/>
            </mx:series>
        </mx:ColumnChart>
    </mx:Panel>
</s:Application>
The hard coded ColumnSeries (the first one) works fine, but the next series which are created dynamically don't work. What's wrong in my code? Any help would be much appreciated.
    May 24, 2013 7:56 AM   in reply to Farhad Navaei
    Hi, check your loop.
    Move ac1 = new ArrayCollection(); out of the loop, like:
                        if(str == obj.loc)
    But I am not sure if this what you need.
    Best,
    May 29, 2013 5:41 AM   in reply to Farhad Navaei
    Glad to hear that, please try to mark your question answered.
