NeutraFace x64
Color Matching
May 24, 2013 4:36 AM
Tags: #color
Hi there!
Is there any way to match close colors? I have two images, and I want to match the color of those through Adjustments i.e. Saturation, Brightness, etc. Attached is a same portion for both of the photos. Thank you.
  • Noel Carboni
    Dec 23, 2006
    May 24, 2013 8:54 AM   in reply to NeutraFace x64
    You might try the Image - Adjustments - Match Color function.
    The other possibility that comes to mind is to set up the Bucket Fill tool with a small but sufficient tolerance, then sample colors from the other image, and bucket-fill them in the target image.  This could be facilitated by putting both images up side by side via the Window - Arrange function, then using Alt-click to sample the color, and just click to fill it.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    May 25, 2013 1:47 PM   in reply to NeutraFace x64
    Did you try Image - Adjustments - Match Color?  Did it work, or at least get you close, to where you could tidy things up with the bucket?
    -Noel
