Gijsbert_Schippers
Spot channel
May 24, 2013 1:55 AM
With printing, does a spot channel behave in the same way as a spot color in Indesign?
    May 24, 2013 2:51 AM   in reply to Gijsbert_Schippers
    If whoever is doing the actual printing is actually using the spot colors, then yes, there would be no difference...
    Mylenium
    May 24, 2013 3:26 AM   in reply to Gijsbert_Schippers
    If you don't prepare your documents differently, then yes, the spot colors will print under/ over your other colors. If you don't want that, you will have to remove the areas either by erasing them or excluding them later in Acrobat/ your RIP software, but then you will also have to deal with trapping and overprint issues to avoid gaps.
    Mylenium
