actionsketch
FLV in flash player stuttering
May 24, 2013 3:43 PM
Tags: #flash #video #flv #actionscript #stuttering
My FLV plays smoothly in VLC, Windows Media Player and Adobe Media Player.
If I load the same movie into flash, either by streaming, embedding, using software rendering or hardware rendering... it stutters uncontrollably. Here's my code:
package
    import flash.display.Sprite;
    import flash.events.AsyncErrorEvent;
    import flash.events.NetStatusEvent;
    import flash.events.StageVideoAvailabilityEvent;
    import flash.media.StageVideo;
    import flash.media.StageVideoAvailability;
    import flash.media.Video;
    import flash.net.NetConnection;
    import flash.net.NetStream;
    [SWF(width='760',height='500')]
    public class VideoPlayer extends Sprite
        [Embed(source = "_example.flv", mimeType = "application/octet-stream")]
        private var VideoBytes:Class;
        private var _netStream:NetStream;
        public function VideoPlayer()
            var nc:NetConnection = new NetConnection();
            nc.addEventListener(NetStatusEvent.NET_STATUS , onStreamStatus);
            nc.connect(null);
            _netStream = new NetStream(nc);
            _netStream.addEventListener(NetStatusEvent.NET_STATUS, onStreamStatus);
            _netStream.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler);
            _netStream.client = this;
            //playNormally();
            //playEmbedded();
            playHardwareAccelerated();
        private function playEmbedded():void
            var video:Video = new Video(stage.stageWidth, stage.stageHeight);
            video.attachNetStream(_netStream);
            addChild(video);
            _netStream.play(null);
            _netStream.appendBytes(new VideoBytes());
        private function playNormally():void
            addChild(video);
            _netStream.play("_example.flv");
        private function playHardwareAccelerated():void
            if( !stage.stageVideos.length ) stage.addEventListener(StageVideoAvailabilityEvent.STAGE_VIDEO_AVAILA BILITY, onStageVideoState);
            else onStageVideoState(null);
        private function onStageVideoState(e:StageVideoAvailabilityEvent):void{
            if(e == null || e.availability == StageVideoAvailability.AVAILABLE){
                var stageVideo:StageVideo = stage.stageVideos[1];
                stageVideo.attachNetStream(_netStream);
                _netStream.play("_scene.flv");
            else trace("StageVideo Unavailable");
        public function asyncErrorHandler(event:AsyncErrorEvent):void { trace(event.text); }
        public function onStreamStatus(e:NetStatusEvent):void { trace(e.info.code); }
        public function onMetaData( info:Object ) : void { trace("onMetaData:"); traceObject(info, 1); }
        public function onCuePoint( info:Object ) : void { trace("onCuePoint:"); traceObject(info, 1); }
        public function onXMPData( info:Object ) : void { trace("onXMPData:"); traceObject(info, 1); }
        public function onLastSecond( info:Object ) : void { trace("onLastSecond:"); traceObject(info, 1); }
        public function traceObject(obj:Object, indent:uint = 0):void
            var indentString:String = "";
            for(var i:uint = 0; i < indent; i++) indentString += "\t";
            if(obj == null) trace(indentString + " null");
            else{
                var isEmpty:Boolean = true;
                for(var prop:String in obj){
                    var val:* = obj[prop];
                    isEmpty = false;
                    if(typeof(val) == "object"){
                        trace(indentString + " " + prop + ": [Object]");
                        traceObject(val, indent + 1);
                    else trace(indentString + " " + prop + ": " + val);
                if( isEmpty ) trace(indentString + " empty");
and here's my FLV
I'm at a loss for what to do about this... and the answer might very well be that the flash FLV renderer isn't good enough to display my flv smoothly, unlike every other FLV player I've tried. But, this is a big deal for my project and I have got to find a solution.
Thanks!
