MKR Edit
Inverted Crop
May 24, 2013 5:18 PM
I've looked around and I can't seem to find any info on this. Is there a way to invert a crop? Instead of croping from the outside in is there a way to crop from the inside out?
    May 24, 2013 11:26 PM   in reply to MKR Edit
    Not crop, but you could animate a garbage matte.
    May 25, 2013 5:46 AM   in reply to MKR Edit
    If you mean like making a hole: use a reversed track matte (shapes can be made in the titler) or the circle effect.
    What is it you want to achive exactly?
    May 25, 2013 10:25 AM   in reply to MKR Edit
    What do you wish to see "through" that "hole?"
    If Video, or a Still Image, would a PiP (Picture in Picture) not accomplish that?
    May 25, 2013 10:54 AM   in reply to MKR Edit
    Track Mattes are good for shapes and gradients. Just use a Photoshop .psd with transparency and the track matte can apply that to a video source.
    You can also use your title maker to create a matte image for a track matte.
    Can you be more specific about waht you are trying to do?
    May 25, 2013 12:13 PM   in reply to Stephen_Spider
    I've been using the reverse track matte method and it has worked without issue. One of the systems we have is a bit under powered and I was trying to cut down on its need to render. I wanted to be sure I wasn't missing some obvious toggle that would accomplish the same thing.
    Thank you all for your quick responses.
