Playback Lag in Premiere Pro CS6 for Mac
May 25, 2013 5:41 AM
Tags: #problem #pro #mac #premiere_pro #premiere #cs6 #project #premiere_pro_cs6
I'm editing a project in Premiere Pro CS6 for Mac, and the playback is really laggy. Its fine if you're viewing one long clip, but it gets really laggy when it switches between clips. The sound will play, but the playback screen will be frozen on the last frame from the previous clip. I use the latest thin model of the iMac. Can anybody help me?
    May 25, 2013 8:35 AM   in reply to zach_green8
    >editing a project
    I have read that it takes a "monster" computer to edit RED video... is that what you are doing?
    More information needed for someone to help... please click below and provide the requested information
    -Information FAQ http://forums.adobe.com/message/4200840
    May 25, 2013 6:44 PM   in reply to zach_green8
    OK... AVCHD takes a LOT of computing power to "effectively" edit
    So... some Information FAQ questions that you did not answer
    What version of Premiere Pro? Include the minor version number (e.g., Premiere Pro CS5.5 with the 5.5.2 update)
    Tell us about your computer hardware
    -such as... what CPU... i3 or i5 or i7
    -such as... how much installed memory
    -such as... how many and what speed hard drive (one 5400rpm drive... or...???)
    Are you using Mercury Playback Engine GPU Acceleration?
    May 26, 2013 7:25 AM   in reply to zach_green8
    >Premiere Pro CS6 with the 6.0.0 update
    Is there a specific reason you have not applied the bug fix updates?
    All Adobe updates start here and select product, read to see if you need to install
    updates in number order, or if the updates are cumulative for the individual product
    http://www.adobe.com/downloads/updates/
    Also, only having one hard drive means your computer is having to "struggle" with file operations
    An EXAMPLE concerning trying to use only ONE Hard Drive for Video Editing
    You are a music conductor, with a baton that you use to point to various parts of the
    orchestra... this is like Windows pointing to various parts of the hard drive to do
    Windows housekeeping or to load program segments for various functions
    Now, at the same time and with the same hand... while still using the baton to conduct
    the orchestra... pick up a bow and play a fiddle... this would be doing something with
    your video file at the same time as all the other work
    You as a person cannot do both at the same time with the same hand
    A computer is a LITTLE better, in that it can switch from one kind of task to another
    very quickly... but not quickly enough for EASY video editing
    You need AT LEAST two hard drives (separate drives, never a partition
    http://forums.adobe.com/thread/650708 for more on partitions) with Windows (or Mac OS)
    and software on your boot drive, and video files on a 2nd drive so the boot drive is
    not slowed down by trying to do everything
    External eSata or USB3 are both fast enough for video editing... eSata is better -
    http://forums.adobe.com/thread/1117813
    Do not try to use USB2 for video editing, it is too slow
    Dock with fan http://www.amazon.com/StarTech-SuperSpeed-Docking-Station-
    Cooling/dp/B0055PL2YI
    May 26, 2013 8:38 AM   in reply to zach_green8
    Can't speak to the Mac platform, but on Windows machines, including high-end Windows machines, AVCHD and AVC-Intra footage can display the kinds of lags you're describing in PPro, when moving from cut to cut.
    If you have an earlier version (5.5, 5.0), you might want to try it:  this problem supposedly didn't exist prior to CS6.
    Or, as a last resort, transcode everything to ProRes or similar intermediate codec.  However, since your one drive could be a problem, you want to do some tests, first.....
