LikeSheDid
Fill Issue
May 25, 2013 11:44 AM
Tags: #photoshop_cs6_mac
Regardless of the file I'm working on or the color I choose, it only fills with basic gray.
    May 25, 2013 11:49 AM   in reply to LikeSheDid
    Welcome to the forum.
    OK, you have a Closed Path/Shape (visible in the Paths Palette). You wish to Fill that Closed Path/Shape with a selected Foreground Color, which appears in the Colors section of the Toolbar. What type of Layer are trying to Fill to? This can be very important, as if you are working in an Adjustment Layer, you will only get black, or white, or gray. If you happen to have a Channel (say from a Layer Mask), you will only Fill with black, or delete parts of the Mask with white.
    Can you post a screen-cap of your Image with the Colors section of the Toolbar, the Layers Palette, the Paths Palette and the Channels Palette visible - just as they appear, when you attempt to Fill your Closed Path with the selected color? That will tell us a lot, and likely point out why you are having problems.
    May 25, 2013 2:04 PM   in reply to LikeSheDid
    Opt-Backspace is a handy shortcut for Fill with foreground colour, by the way.
    Cmd-Backspace for Fill with background colour.
