annabelle201o
PPro opening slowly for insisting projects
May 26, 2013 9:51 PM
I'm having problems with previosuly saved projects opening vry slowly with CS6, I have 12 gigs RAM with a solid state 60gb main drive that hosts the windows 7 OS and data drive and then four drives controlledby a raid controller card. One the project is open everything works well, just takes several minutes for projects to open. Suggestions?
  • joe bloe premiere
    Dec 6, 2009
    May 27, 2013 8:06 AM   in reply to annabelle201o
    What is the file size of your .prproj file?
    Does your Project contain a lot of individual Sequences?
    Have you used the Warp Stabilizer in your Project?
    Do you have a lot of Dynamically Linked elements in your Project?
    When you open your Project, can you see (bottom left of interface)
    all of the media files being located and loaded into the Project?
    If you have lots of source media, this can take some time to complete:
  • joe bloe premiere
    Dec 6, 2009
    May 27, 2013 10:24 AM   in reply to annabelle201o
    Four Sequences is not very many.
    You can check your Project file size by looking at the .prproj file.
    Dynamic Linked elements are obviously not the problem (since
    you don't know what they are, I doubt you have used them).
    What is shown above appears on the bottom left of the interface.
    That is an indication of the media files being located and loaded
    into the Project.  Note the circled progress '(14 remaining)'.
    What you will see on the bottom right will be audio files conforming
    (note the yellow bar indicating the progress of a single media file).
    Do not interrupt the conforming process, and allow plenty of time
    for all files to complete conforming before you try to start editing.
    If your Project is re-conforming audio files every time you
    open the Project, that may be another problem.
