RickChicago
Dreamweaver 12.0 - Fluid Grid Layout problem - I have 12 columns - but some DIV's are too wide
May 26, 2013 9:50 PM
http://skicmsc.org/NewResponsive.htm
Working on a new look for a current site.  I have 16 columns. Left div is 3 columns, next is 7 columns, then 3 and 3. Total: 16
The 7 column Div is pushing the right Div's off the layout by several "columns". If I delete the thing, everything is fine. Make it just 2 columns wide and the layout is messed up.  I've tried naming it different things, starting from scratch - twice. Still have the same problem. Deleted, recreated, moved up and down. Nested and not nested.  Next step is to say forget it.  Wasted four hours on this already.
Screen grab of the layout - all looks nice and clean.
Here's what it looks like (In Chrome, IE and Firefox.)
What's really annoying - undo/Ctrl-Z does not undo "visual" changes.  I can edit text, resize a Div by dragging the right handle, do an Undo - and my text edit is changed - not the resize.
Any suggestions?
Rick Drew
    May 26, 2013 10:09 PM   in reply to RickChicago
    May 27, 2013 9:53 AM   in reply to RickChicago
    For best results, your LayoutDivs need to be wrapped inside the .gridContainer as it serves as the basic structure for your entire  layout (mobile, tablet and desktop).
    <div class="gridContainer clearfix">
         <div id="LayoutDiv1">
         </div>
         <div id="LayoutDiv2">
         </div>
         <div id="LayoutDiv3">
         </div>
         <div id="LayoutDiv4">
         </div>
    <!--end gridContainer--></div>
    Design View Screenshot
    When you put Divs outside the .gridContainer, this can create rounding problems in many browsers because the inner div widths are all set in fractional percentages rather than whole numbers.  Browsers don't fully understand how to render widths in fractions.
    In the following example, I have the same set-up as shown in my screenshot above except my footer div is intentionally located outside the gridContainer.  This allows my footer to be 100% page width.
    http://alt-web.com/FluidGrid/Fluid1.html
    If you understand and work within the limitations of FluidGridLayouts, they can save you a lot of time.
    Nancy O.
    May 28, 2013 9:50 PM   in reply to RickChicago
    Hi Rick,
    I looked at the URL you gave(in IE) and couldn't see this problem anymore. has that been resolved ?
    This doesn't looks like a rounding problem to me as it will just shift a div marginally.
    Yes this is a bit of PIA, the reason being some actions like, resize will have a CSS only impact while others like swaping the elements etc have both HTML and CSS updates.
    and currently Undo will only work on the current file which is in focus (I.e HTML/source Code or CSS).
    Hence, in nut shell, if you did a resize and then you are trying to do undo such that you focus is not on CSS file, it wont work.
    to work around this , just switch to CSS code and then do undo and life is good again.
