ChrisKoethe
Creating PDF brochure for printing: Remove white margin
May 27, 2013 2:14 AM
Hi guys,
I created a brochure in Idesign which has a black background color.
In order to print the brochure I want to create a PDF (with the right order of pages, e.g. page 1 next to page 8, 2 next to 7 etc.) via the "print function".
The page order is not a problem, but unfotunately I always get a white margin although there is no such in the original indesign document.
(When using the normal "export function" of Indesign there is no white margin, but then I cannot create a PDF with the right page order for printing...)
Has anyone an idea how to solve this?
Thanks for your help in advance!
Best,
Chris
    May 27, 2013 6:22 AM   in reply to ChrisKoethe
    Add bleed to your pages, then print it with Print Booklet
    You can also try IDImposer
    http://idimposer.com/
    May 27, 2013 6:37 AM   in reply to ChrisKoethe
    In order to print with bleed you generally need to print onto a larger sheet and trim. I'm guessing you are trying to print this on a desktop printer of some sort, and unless specifically designed for "borderless" printing they always have a border along the edge that cannont be imaged.
