Lordenzia
Adjusting a flattened image file
May 31, 2013 4:56 AM
Tags: #photoshop #layers #image_quality #flatted_image #image_degradation
Hello!
Does anyone know an aswer to this question I´m pondering:
If I go on adjusting a psd-file which has been flattened, will the file´s image quality go worse?
Meaning that I´ve had a TIFF-file (made from a RAW-file) that I have adjusted with plenty of layers. After all the adjustments, I´ve made a copy of it, flattened the copied file, cropped it to the wanted size (no interpolation), and made some changes again with cloning tools and gaussian blur. But after this, I find I still have to make another version of the image with different adjustments of lightness (curves) and colors (color balance, saturation) and I´m pondering if I have to go back to the file with layers, or can I continue with the cropped file and make new adjustment layers on this flattened image. Would be better for the work flow and my nerves...
Thank you for anyone who got energy to read this and maybe help me!
    May 31, 2013 5:51 AM   in reply to Lordenzia
    Basically any Adjustment will be detrimental – but usually the deterioration with Adjustments that are not extreme is (close to) unnoticeable.
    Working in 16bit can help keep the detrimental effects smaller than when working with 8bit images.
    Do you get banding?
    It’s your image, so it’s up to you to decide if the image deterioration is so bad as to warrant starting over.
    Why did you not continue working with the layered file anyway?
